Conference papers
Effect of the torso conductivity heterogeneities on the ECGI inverse problem solution
Abstract : The effect of torso conductivity heterogeneities on the electrocardiographic imaging (ECGI) inverse problem solution is still subject of debate. In this study we present a method to assess the effect of these heterogeneities. We use an anatomical model containing the heart the lungs the bones and the torso surfaces. We use the bidomain model and we solve it using finite element methods in order to generate in silico data taking into account the torso heterogeneities. We add different noise levels on the body surface potentials and we solve the inverse problem for both homogenous and heterogeneous torso conductivities. We analyse the reconstructed solution using the relative error and the correlation coefficient.
Document type :
Conference papers
Complete list of metadata
Cited literature [13 references]  Display  Hide  Download
https://hal.inria.fr/hal-01241750
Contributor : Nejib Zemzemi Connect in order to contact the contributor
Submitted on : Thursday, December 10, 2015 - 11:33:30 PM
Last modification on : Monday, July 25, 2022 - 3:44:12 AM
Long-term archiving on: : Saturday, April 29, 2017 - 11:41:52 AM
File
cinc2015.pdf
Identifiers
  • HAL Id : hal-01241750, version 1
Citation
Nejib Zemzemi, Cecile Dobrzynski, Laura Bear, Mark Potse, Corentin Dallet, et al.. Effect of the torso conductivity heterogeneities on the ECGI inverse problem solution. Computing in cardiology, Sep 2015, Nice, France. ⟨hal-01241750⟩
Share
Metrics
Record views
226
Files downloads
221
