Inverse Solution Mapping of Epicardial Potentials: Quantitative Comparison With Epicardial Contact Mapping, Circulation: Arrhythmia and Electrophysiology, vol.5, issue.5, pp.1001-1009, 2012. ,
DOI : 10.1161/CIRCEP.111.970160
Cardiac Arrythmias: Multimodal Assessment Integrating Body Surface ECG Mapping into Cardiac Imaging, Radiology, vol.271, issue.1, pp.239-247, 2014. ,
DOI : 10.1148/radiol.13131331
A model for human ventricular tissue, AJP: Heart and Circulatory Physiology, vol.286, issue.4, pp.1573-89, 2003. ,
DOI : 10.1152/ajpheart.00794.2003
Relating Epicardial to Body Surface Potential Distributions by Means of Transfer Coefficients Based on Geometry Measurements, IEEE Transactions on Biomedical Engineering, vol.24, issue.1, pp.241-252, 1977. ,
DOI : 10.1109/TBME.1977.326201
Application of the Method of Fundamental Solutions to Potential-based Inverse Electrocardiography, Annals of Biomedical Engineering, vol.46, issue.6, pp.341272-88, 2006. ,
DOI : 10.1007/s10439-006-9131-7
Redundancy reduction for improved display and analysis of body surface potential maps. I. Spatial compression, Circulation Research, vol.49, issue.1, pp.49197-203, 1981. ,
DOI : 10.1161/01.RES.49.1.186
Multi-lead ECG electrode array for clinical application of electrocardiographic inverse problem, The 26th Annual International Conference of the IEEE Engineering in Medicine and Biology Society, pp.1-1941, 2004. ,
DOI : 10.1109/IEMBS.2004.1403574
Methods of Solving Reduced Lead Systems for Inverse Electrocardiography, IEEE Transactions on Biomedical Engineering, vol.54, issue.2, pp.54339-54382, 2007. ,
DOI : 10.1109/TBME.2006.886865
A Field-Compatible Method for Interpolating Biopotentials, Annals of Biomedical Engineering, vol.26, issue.1, pp.37-47, 1998. ,
DOI : 10.1114/1.49
