A Symbiotic Approach to Designing Cross-Layer QoS in Embedded Real-Time Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nowadays there is an increasing need for embedded systems to support intensive computing while maintaining traditional hard real-time and fault-tolerant properties. Extending the principle of multi-core systems, we are exploring the use of distributed processing units interconnected via a high performance mesh network as a way of supporting distributed real-time applications. Fault-tolerance can then be ensured through dynamic allocation of both computing and communication resources. We postulate that enhancing QoS (Quality of Service) for real-time applications entails the development of a cross-layer support of high-level requirements, thus requiring a deep knowledge of the underlying networks. In this paper, we propose a new simulation/emulation/experimentation framework, ERICA, for designing such a feature. ERICA integrates both a network simulator and an actual hardware network to allow implementation and evaluation of different QoS-guaranteeing mechanisms. It also supports real-software-in-the-loop, i.e. running of real applications and middleware over these networks. Each component can evolve separately or together in a symbiotic manner, also making teamwork more flexible. We present in more detail our discrete-event simulation approach and the in-silicon implementation with which we cross-check our solutions in order to bring real performance aspects to our work. We also discuss the challenges of running real-software-in-the-loop in a real-time context, i.e. how to bridge it with a network simulator, and how to deal with time consistency.
ERTS_16_tosend.pdf (1.59 Mo) Télécharger le fichier
hal-01242068 , version 1 (11-12-2015)
  • HAL Id : hal-01242068 , version 1
Florian Greff, Eric Dujardin, Arnaud Samama, Ye-Qiong Song, Laurent Ciarletta. A Symbiotic Approach to Designing Cross-Layer QoS in Embedded Real-Time Systems. 8th European Congress on Embedded Real Time Software and Systems (ERTS 2016)", Jan 2016, Toulouse, France. ⟨hal-01242068⟩
589 Consultations
363 Téléchargements
