Entropy-satisfying scheme for a hierarchy of dispersive reduced models of free surface flow, Part I - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
This work is devoted to the numerical resolution in multidimensional framework of a hierarchy of reduced models of the free surface Euler equations, also called water waves equations. The current paper, the first in a series of two, focuses on a hierarchy of monolayer dispersive models, such is the Serre-Green-Naghdi model. A particular attention is given to the dissipation of the mechanical energy at the discrete level, i.e. to design an entropy-satisfying scheme. To illustrate the accuracy and the robustness of the strategy, several numerical experiments are performed. In particular, the strategy is able to deal with dry areas without particular treatment.
GN_V1.0_public.pdf (4.47 Mo) Télécharger le fichier
hal-01242128 , version 2 (26-09-2017)
hal-01242128 , version 3 (26-02-2018)
hal-01242128 , version 4 (25-07-2019)
  • HAL Id : hal-01242128 , version 2
Martin Parisot. Entropy-satisfying scheme for a hierarchy of dispersive reduced models of free surface flow, Part I. 2017. ⟨hal-01242128v2⟩
526 Consultations
727 Téléchargements
