New interface
Conference papers
Coqoon An IDE for interactive proof development in Coq
Abstract : User interfaces for interactive proof assistants have always lagged behind those for mainstream programming languages. Whereas integrated development environments—IDEs—have support for features like project management, version control, dependency analysis and in-cremental project compilation, " IDE " s for proof assistants typically only operate on files in isolation, relying on external tools to integrate those files into larger projects. In this paper we present Coqoon, an IDE for Coq developments integrated into Eclipse. Coqoon manages proofs as projects rather than isolated source files, and compiles these projects using the Eclipse common build system. Coqoon takes advantage of the latest features of Coq, including asynchronous and parallel processing of proofs, and—when used together with a third-party OCaml extension for Eclipse—can even be used to work on large developments containing Coq plugins.
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/hal-01242295
Contributor : Enrico Tassi Connect in order to contact the contributor
Submitted on : Friday, December 11, 2015 - 5:23:41 PM
Last modification on : Friday, August 5, 2022 - 12:35:03 PM
Long-term archiving on: : Saturday, April 29, 2017 - 12:07:33 PM
File
main.pdf
Identifiers
  • HAL Id : hal-01242295, version 1
Collections
Citation
Alexander Faithfull, Jesper Bengtson, Enrico Tassi, Carst Tankink. Coqoon An IDE for interactive proof development in Coq. TACAS, Apr 2016, Eindhoven, Netherlands. ⟨hal-01242295⟩
Share
Metrics
Record views
183
Files downloads
587
