Stochastic simulators based optimization by Gaussian process metamodels -Application to maintenance investments planning issues Short title: Metamodel-based optimization of stochastic simulators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Quality and Reliability Engineering International Année : 2016
This paper deals with the optimization of industrial asset management strategies, whose profitability is characterized by the Net Present Value (NPV) indicator which is assessed by a Monte Carlo simulator. The developed method consists in building a metamodel of this stochastic simulator, allowing to get, for a given model input, the NPV probability distribution without running the simulator. The present work is concentrated on the emulation of the quantile function of the stochastic simulator by interpolating well chosen basis functions and metamodeling their coefficients (using the Gaussian process metamodel). This quantile function metamodel is then used to treat a problem of strategy maintenance optimization (four systems installed on different plants), in order to optimize an NPV quantile. Using the Gaussian process framework, an adaptive design method (called QFEI) is defined by extending in our case the well known EGO algorithm. This allows to obtain an " optimal " solution using a small number of simulator runs.
QREI_V5.pdf (666.99 Ko) Télécharger le fichier
hal-01242478 , version 1 (12-12-2015)
hal-01242478 , version 2 (03-05-2016)
Thomas Browne, Bertrand Iooss, Loïc Le Gratiet, Jérôme Lonchampt, Emmanuel Remy. Stochastic simulators based optimization by Gaussian process metamodels -Application to maintenance investments planning issues Short title: Metamodel-based optimization of stochastic simulators. Quality and Reliability Engineering International, 2016, 32 (6). ⟨hal-01242478v2⟩
241 Consultations
237 Téléchargements
