New interface
Journal articles
Improving Fiber Alignment in HARDI by Combining Contextual PDE Flow with Constrained Spherical Deconvolution
Abstract : We propose two strategies to improve the quality of tractography results computed from diffusion weighted magnetic resonance imaging (DW-MRI) data. Both methods are based on the same PDE framework, defined in the coupled space of positions and orientations, associated with a stochastic process describing the enhancement of elongated structures while preserving crossing structures. In the first method we use the enhancement PDE for contextual regularization of a fiber orientation distribution (FOD) that is obtained on individual voxels from high angular resolution diffusion imaging (HARDI) data via constrained spherical deconvolution (CSD). Thereby we improve the FOD as input for subsequent tractography. Secondly, we introduce the fiber to bundle coherence (FBC), a measure for quantification of fiber alignment. The FBC is computed from a tractography result using the same PDE framework and provides a criterion for removing the spurious fibers. We validate the proposed combination of CSD and enhancement on phantom data and on human data, acquired with different scanning protocols. On the phantom data we find that PDE enhancements improve both local metrics and global metrics of tractography results, compared to CSD without enhancements. On the human data we show that the enhancements allow for a better reconstruction of crossing fiber bundles and they reduce the variability of the tractography output with respect to the acquisition parameters. Finally, we show that both the enhancement of the FODs and the use of the FBC measure on the tractography improve the stability with respect to different stochastic realizations of probabilistic tractography. This is shown in a clinical application: the reconstruction of the optic radiation for epilepsy surgery planning.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-01242740
Contributor : Demian Wassermann Connect in order to contact the contributor
Submitted on : Monday, December 14, 2015 - 8:37:28 AM
Last modification on : Saturday, June 25, 2022 - 11:17:48 PM
Links full text
Identifiers
Collections
Citation
Jorg M. Portegies, Rutger H.J. Fick, Gonzalo R. Sanguinetti, Stephan Meesters, Gabriel Girard, et al.. Improving Fiber Alignment in HARDI by Combining Contextual PDE Flow with Constrained Spherical Deconvolution. PLoS ONE, 2015, 10 (10), ⟨10.1371/journal.pone.0138122⟩. ⟨hal-01242740⟩
Share
Metrics
Record views
75
