New interface
Conference papers
On Flow-Aware CSMA in Multi-Channel Wireless Networks
Abstract : We consider a multi-channel wireless network with flow-aware CSMA, which consists in running one instance of the CSMA algorithm per active flow. Specifically, each such instance attempts to access a randomly chosen radio channel after some random time and transmits a packet of the corresponding flow if the channel is sensed idle. We prove that, unlike the standard CSMA algorithm, this simple distributed access scheme is optimal in the sense that the network is stable for all traffic intensities in the capacity region of the network.
Complete list of metadata
https://hal.inria.fr/hal-01244034
Contributor : Thomas Bonald Connect in order to contact the contributor
Submitted on : Tuesday, December 15, 2015 - 2:17:53 PM
Last modification on : Friday, January 21, 2022 - 3:22:00 AM
Identifiers
  • HAL Id : hal-01244034, version 1
Citation
Thomas Bonald, Mathieu Feuillet. On Flow-Aware CSMA in Multi-Channel Wireless Networks. CISS, 2011, Baltimore, United States. ⟨hal-01244034⟩
Share
Metrics
Record views
66
