New interface
Preprints, Working Papers, ...
Combinatorial optimization methods to complete and analyse a metabolic network
Julie Laniau 1 Anne Siegel 1 Damien Eveillard 2
1 Dyliss - Dynamics, Logics and Inference for biological Systems and Sequences
Inria Rennes – Bretagne Atlantique , IRISA-D7 - GESTION DES DONNÉES ET DE LA CONNAISSANCE
Abstract : Biological compartments have a important role with respect to the struc- turation of metabolic map and to the control of metabolic transformations within a cell. Such compartments highlight the role of speci?c compounds, namely those transported from a compartment to another, which can be view as metabolite crossroads. We will call them "intermediary metabo- lites". The goal of this talk will be to study the impact of such intermediary metabolite when one is reconstructing a metabolic map from genome scale data. More precisely, genome annotation allow to identify a set of metabolic reactions which are active in a given species. Although, very often, these reactions are not su?cient to explain the production of compounds which are experimentally characterized. In this case, we need to propose reac- tions to be added to the metabolic map in order to explain the production of the targeted metabolic compounds. Such gap-?lling algorithms rarely take into account the existence of internal crossroads in the metabolic map. To that goal, we will model the role of intermediary metabolites in terms of combinatorial constraints. Then we will study the role of intermediary metabolites on a gap?lling method based on ASP (answer set programming) technologies. The method will be illustrated on large-scale yeast data.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-01244179
Contributor : Julie Laniau Connect in order to contact the contributor
Submitted on : Tuesday, December 15, 2015 - 2:48:07 PM
Last modification on : Wednesday, April 27, 2022 - 3:50:00 AM
File
jlaniau.pdf
Identifiers
  • HAL Id : hal-01244179, version 1
Citation
Julie Laniau, Anne Siegel, Damien Eveillard. Combinatorial optimization methods to complete and analyse a metabolic network. {date}. ⟨hal-01244179⟩
Share
Metrics
Record views
61
Files downloads
35
