GetDDM: an open framework for testing optimized Schwarz methods for time-harmonic wave problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Physics Communications Année : 2016
We present an open finite element framework, called GetDDM, for testing optimized Schwarz domain decomposition techniques for time-harmonic wave problems. After a review of Schwarz domain decomposition methods and associated transmission conditions, we discuss the implementation, based on the open source software GetDP and Gmsh. The solver, along with ready-to-use examples for Helmholtz and Maxwell’s equations, is freely available online for further testing.
DDM_getdp.pdf (2.63 Mo) Télécharger le fichier
hal-01244511 , version 1 (03-02-2016)
Paternité
Bertrand Thierry, Alexandre Vion, Simon Tournier, Mohamed El Bouajaji, David Colignon, et al.. GetDDM: an open framework for testing optimized Schwarz methods for time-harmonic wave problems. Computer Physics Communications, 2016, 203, pp.309-330. ⟨10.1016/j.cpc.2016.02.030⟩. ⟨hal-01244511⟩
704 Consultations
287 Téléchargements
