List decoding of Hermitian codes using Gr??bner bases, Journal of Symbolic Computation, vol.44, issue.12, pp.1662-1675, 2009. ,
DOI : 10.1016/j.jsc.2007.12.004
Efficient list decoding of a class of algebraic-geometry codes, Adv. Mathematics of Comm, vol.4, pp.485-518, 2010. ,
Linear Diophantine Equations Over Polynomials and Soft Decoding of Reed???Solomon Codes, IEEE Transactions on Information Theory, vol.51, issue.7, pp.2257-2265, 2005. ,
DOI : 10.1109/TIT.2005.850097
On the complexity of polynomial matrix computations, Proceedings of the 2003 international symposium on Symbolic and algebraic computation , ISSAC '03, pp.135-142, 2003. ,
DOI : 10.1145/860854.860889
Power Decoding of Reed???Solomon Codes Revisited, ICMCTA, 2014. ,
DOI : 10.1007/978-3-319-17296-5_32
Generalized Berlekamp-Massey decoding of algebraic-geometric codes up to half the Feng-Rao bound, IEEE Transactions on Information Theory, vol.41, issue.6, pp.1762-1768, 1995. ,
DOI : 10.1109/18.476248
A note on Hermitian codes over GF(q/sup 2/), IEEE Transactions on Information Theory, vol.34, issue.5, pp.1345-1348, 1988. ,
DOI : 10.1109/18.21267
Interpolation and List Decoding of Algebraic Codes, 2010. ,
Algebraic Function Fields and Codes, 2009. ,
On the true minimum distance of Hermitian codes, Coding Theory and Algebraic Geometry, pp.99-107, 1992. ,
DOI : 10.1007/BFb0087995
Solving generalised Padé approximations over polynomial rings, Preprint, 2014. ,
List Decoding of Algebraic Codes, 2013. ,
On lattice reduction for polynomial matrices, Journal of Symbolic Computation, vol.35, issue.4, pp.377-401, 2003. ,
DOI : 10.1016/S0747-7171(02)00139-6
Computing minimal nullspace bases, Proceedings of the 37th International Symposium on Symbolic and Algebraic Computation, ISSAC '12, pp.366-373, 2012. ,
DOI : 10.1145/2442829.2442881
Normalization of row reduced matrices, Proceedings of the 36th international symposium on Symbolic and algebraic computation, ISSAC '11, pp.297-304, 2011. ,
DOI : 10.1145/1993886.1993931
Generalised Multi-sequence Shift-Register synthesis using module minimisation, 2013 IEEE International Symposium on Information Theory, 2013. ,
DOI : 10.1109/ISIT.2013.6620353
Improved decoding of Reed-Solomon and algebraic-geometric codes, Proceedings 39th Annual Symposium on Foundations of Computer Science (Cat. No.98CB36280), pp.1757-1767, 1999. ,
DOI : 10.1109/SFCS.1998.743426
The Decoding of Algebraic Geometry Codes, Advances in Algebraic Geometry Codes (E. Martínez-Moro, 2008. ,
DOI : 10.1142/9789812794017_0002
Ideal forms of Coppersmith's theorem and Guruswami-Sudan list decoding, Advances in Mathematics of Communications, vol.9, issue.3, 1284. ,
DOI : 10.3934/amc.2015.9.311
Efficient root-finding algorithm with application to list decoding of algebraic-geometric codes, IEEE Trans. Inf. Theory, vol.47, issue.6, pp.2579-2587, 2001. ,
Efficient decoding of Reed-Solomon codes beyond half the minimum distance, IEEE Transactions on Information Theory, vol.46, issue.1, pp.246-257, 2000. ,
DOI : 10.1109/18.817522
Fast decoding of codes from algebraic plane curves, IEEE Transactions on Information Theory, vol.38, issue.1, pp.111-119, 1992. ,
DOI : 10.1109/18.108255
Syndrome Decoding of Reed–Solomon Codes Beyond Half the Minimum Distance Based on Shift-Register Synthesis, IEEE Transactions on Information Theory, vol.56, issue.10, pp.5245-5252, 2010. ,
DOI : 10.1109/TIT.2010.2060130
Bounds on collaborative decoding of interleaved Hermitian codes and virtual extension, Designs, Codes and Cryptography, pp.1-17, 2012. ,
DOI : 10.1007/s10623-012-9625-2
Decoding interleaved Reed?Solomon and Hermitian codes with generalized divisions, Proc. of SCC, pp.1-6, 2013. ,
Unambiguous decoding of generalized Reed?Solomon codes beyond half the minimum distance, Proc. of IZS, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-01120389
Performance analysis of a decoding algorithm for algebraic-geometry codes, IEEE Transactions on Information Theory, vol.45, issue.5, pp.1712-1717, 1999. ,
DOI : 10.1109/18.771253
Dependent rational points on curves over finite fields - Lefschetz theorems and exponential sums, Proc. of WCC, pp.297-309, 2001. ,
DOI : 10.1016/S1571-0653(04)00181-7
Simplified understanding and efficient decoding of a class of algebraic-geometric codes, IEEE Transactions on Information Theory, vol.40, issue.4, pp.981-1002, 1994. ,
DOI : 10.1109/18.335973
Efficient algorithms for order basis computation, Journal of Symbolic Computation, vol.47, issue.7, pp.793-819, 2012. ,
DOI : 10.1016/j.jsc.2011.12.009
A Fast Decoding Method of AG Codes from Miura-Kamiya Curves Cab up to Half the Feng-Rao Bound, Finite Fields and Their Applications, vol.1, issue.1, pp.83-101, 1995. ,
DOI : 10.1006/ffta.1995.1006
The Design and Analysis Of Computer Algorithms, 1974. ,
Modern Computer Algebra, 2012. ,
DOI : 10.1017/CBO9781139856065
Introduction to algorithms, 2009. ,
