New interface
Preprints, Working Papers, ...
On Smooth Frame Field Design
Nicolas Ray 1 Dmitry Sokolov 1
1 ALICE - Geometry and Lighting
Inria Nancy - Grand Est, LORIA - ALGO - Department of Algorithms, Computation, Image and Geometry
Abstract : We analyze actual methods that generate smooth frame fields both in 2D and in 3D. We formalize the 2D problem by representing frames as functions (as it was done in 3D), and show that the derived optimization problem is the one that previous work obtain via " representation vectors ". We show (in 2D) why this non linear optimization problem is easier to solve than directly minimizing the rotation angle of the field, and observe that the 2D algorithm is able to find good fields. Now, the 2D and the 3D optimization problems are derived from the same formulation (based on representing frames by functions). Their energies share some similarities from an optimization point of view (smoothness , local minima, bounds of partial derivatives, etc.), so we applied the 2D resolution mechanism to the 3D problem. Our evaluation of all existing 3D methods suggests to initialize the field by this new algorithm, but possibly use another method for further smoothing.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-01245657
Contributor : Sokolov Dmitry Connect in order to contact the contributor
Submitted on : Friday, January 8, 2016 - 4:18:49 PM
Last modification on : Saturday, June 25, 2022 - 7:45:02 PM
Long-term archiving on: : Friday, April 15, 2016 - 2:31:51 PM
framefield.pdf
Publisher files allowed on an open archive
Identifiers
Collections
Citation
Nicolas Ray, Dmitry Sokolov. On Smooth Frame Field Design. 2016. ⟨hal-01245657⟩
Share
Metrics
Record views
203
Files downloads
610
