Towards A Debugger for Native-Code OCaml Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Fabrice Le Fessant
Pierre Chambart
  • Fonction : Auteur
  • PersonId : 974039
In this talk, we will present a starting project at OCamlPro, the development of a debugging framework for OCaml native-code applications, based on the LLDB Debugger, a debugger built on top of the LLVM framework. We implemented a complete binding of LLDB C++ API for OCaml, and then used it to build several tools, one " generic " debugger, and two small utilities to monitor the memory behavior of OCaml applications.
main.pdf (120.44 Ko) Télécharger le fichier
hal-01245840 , version 1 (17-12-2015)
  • HAL Id : hal-01245840 , version 1
Fabrice Le Fessant, Pierre Chambart. Towards A Debugger for Native-Code OCaml Applications. OCaml Users and Developers Workshop, Sep 2015, Vancouver, Canada. ⟨hal-01245840⟩
82 Consultations
327 Téléchargements
