035115 (2015) predicts flow statistics in closer agreement with those of the periodic LES than the SST model. Nevertheless , it can be inferred that the eddy-viscosity hypothesis of the SST model, giving ?v ?2 ? = 2k/3, tends to overestimate ?v ?2 ? and thus to promote the shear stress production P 12 = ??v ?2 ???u?/? y downstream of the LES inlet, resulting in a better development of the flow, Using an anisotropic length scale in association with the EB-RSM, Fig. 24 shows that the spatial development of the flow in the LES region is significantly improved ,
Comments of feasibility of LES for wings, and on a hybrid RANS/LES approach, Advances in DNS/LES, Proceedings of the First AFOSR International Conference on DNS/LES, 1997. ,
A Scale-Adaptive Simulation Model for Turbulent Flow Predictions, 41st Aerospace Sciences Meeting and Exhibit, pp.2003-0767, 2003. ,
DOI : 10.2514/6.2003-767
A seamless hybrid RANS-LES model based on transport equations for the subgrid stresses and elliptic blending, Physics of Fluids, vol.22, issue.5, p.55104, 2010. ,
DOI : 10.1063/1.3415254
Multiscale and Multiresolution Approaches in Turbulence, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-01313533
tests of inflow conditions for large-eddy simulation, Physics of Fluids, vol.16, issue.12, pp.777-788, 2004. ,
DOI : 10.1063/1.1811672
Interface Conditions for Hybrid RANS/LES Calculations, Int. J. Heat Fluid Flow, vol.27, pp.777-788, 2006. ,
DOI : 10.1016/B978-008044544-1/50033-9
Reconstruction of turbulent fluctuations for hybrid RANS/LES simulations using a Synthetic-Eddy Method, International Journal of Heat and Fluid Flow, vol.30, issue.3, pp.435-442, 2009. ,
DOI : 10.1016/j.ijheatfluidflow.2009.02.016
Interfacing Statistical Turbulence Closures with Large-Eddy Simulation, AIAA Journal, vol.42, issue.3, pp.485-492, 2004. ,
DOI : 10.2514/1.3496
A synthetic-eddy-method for generating inflow conditions for large-eddy simulations, International Journal of Heat and Fluid Flow, vol.27, issue.4, pp.585-593, 2006. ,
DOI : 10.1016/j.ijheatfluidflow.2006.02.006
Generation of Turbulent Inflow Data for Spatially-Developing Boundary Layer Simulations, Journal of Computational Physics, vol.140, issue.2, pp.233-258, 1998. ,
DOI : 10.1006/jcph.1998.5882
A consistent dual-mesh framework for hybrid LES/RANS modeling, J. Comput. Phys, vol.231, pp.1848-1865, 2012. ,
Generation of turbulent inflow data with a prescribed shear-stress profile, DNS/LES Progress and Challenges, Proceedings of the 3rd AFOSR International Conference on DNS/LES, 2001. ,
A dynamic forcing method for unsteady turbulent inflow conditions, Journal of Computational Physics, vol.230, issue.23, pp.8647-8663, 2011. ,
DOI : 10.1016/j.jcp.2011.08.012
URL : https://hal.archives-ouvertes.fr/hal-01298912
Generation of synthetic turbulent inflow data for large eddy simulation of spatially evolving wall-bounded flows, Physics of Fluids, vol.21, issue.4, p.45103, 2009. ,
DOI : 10.1063/1.3103881
Outflow Conditions for Intregrated Large Eddy Simulation/Reynolds-Averaged Navier-Stokes Simulations, AIAA Journal, vol.43, issue.1, pp.156-164, 2005. ,
DOI : 10.2514/1.11007
Segregated coupling of large-eddy simulations with downstream Reynolds-averaged Navier?Stokes calculations, Comput. Fluids, vol.39, pp.1314-1331, 2010. ,
RANS/LES coupling for unsteady turbulent flow simulation at high Reynolds number on coarse meshes, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.23-24, pp.2939-2960, 2006. ,
DOI : 10.1016/j.cma.2005.06.007
Reconstruction of Turbulent Fluctuations Using a Hybrid RANS/LES Approach, Journal of Computational Physics, vol.182, issue.1, pp.301-336, 2002. ,
DOI : 10.1006/jcph.2002.7169
URL : https://hal.archives-ouvertes.fr/tel-00006002
Linearly forced isotropic turbulence Center of Turbulence Research Annual Research Briefs, pp.123-176, 2003. ,
Linear forcing in numerical simulations of isotropic turbulence: Physical space implementations and convergence properties, Physics of Fluids, vol.17, issue.9, p.95106, 2005. ,
DOI : 10.1063/1.2047568
Elliptic blending model: A new near-wall Reynolds-stress turbulence closure, Physics of Fluids, vol.14, issue.2, pp.744-754, 2002. ,
DOI : 10.1063/1.1432693
An introduction to Computational Fluid Dynamics: The Finite Volume Method (Longman Scientific and Technical, 1995. ,
The temporally filtered Navier???Stokes equations: Properties of the residual stress, Physics of Fluids, vol.15, issue.8, p.2127, 2003. ,
DOI : 10.1063/1.1582858
The tensor equation AX+XA=?(A,H), with applications to kinematics of continua, Journal of Elasticity, vol.65, issue.2, pp.117-153, 1993. ,
DOI : 10.1007/BF00040962
A novel approach to the solution of the tensor equation AX+XA=H, International Journal of Solids and Structures, vol.37, issue.25, pp.3457-3477, 2000. ,
DOI : 10.1016/S0020-7683(99)00053-0
On the derivative of the square root of a tensor and Guo's rate theorems, Journal of Elasticity, vol.42, issue.3, pp.329-336, 1984. ,
DOI : 10.1007/BF00041141
A selection of test cases for the validation of large-eddy simulations of turbulent flows, AGARD Advisory Report, vol.345, 1998. ,
Differential filters for the large eddy numerical simulation of turbulent flows, Physics of Fluids, vol.29, issue.6, pp.1755-1766, 1986. ,
DOI : 10.1063/1.865649
Explicitly filtered large eddy simulation on unstructured grids, Center of Turbulence Research Annual Briefs, vol.87, p.96, 2011. ,
Anisotropic linear forcing for synthetic turbulence generation in large eddy simulation and hybrid RANS/LES modeling, Physics of Fluids, vol.27, issue.3, p.35115, 2015. ,
DOI : 10.1063/1.4916019
URL : https://hal.archives-ouvertes.fr/hal-01246100
The return to isotropy of homogeneous turbulence, Journal of Fluid Mechanics, vol.41, issue.01, pp.161-178, 1977. ,
DOI : 10.1146/annurev.fl.08.010176.001151
Computational Modeling of Turbulent Flows, Adv. Appl. Mech, vol.18, pp.123-176, 1978. ,
DOI : 10.1016/S0065-2156(08)70266-7
Direct numerical simulation of turbulent channel flow up to Re??=590, Physics of Fluids, vol.11, issue.4, pp.943-945, 1999. ,
DOI : 10.1063/1.869966
Temporal filtering: A consistent formalism for seamless hybrid RANS???LES modeling in inhomogeneous turbulence, International Journal of Heat and Fluid Flow, vol.31, issue.3, pp.378-389, 2010. ,
DOI : 10.1016/j.ijheatfluidflow.2009.12.008
Algebraic Modeling of the Turbulent Heat Fluxes Using the Elliptic Blending Approach???Application to Forced and Mixed Convection Regimes, Flow, Turbulence and Combustion, vol.36, issue.8, pp.77-100, 2012. ,
DOI : 10.1007/s10494-011-9366-8
Detached-Eddy Simulation, Annual Review of Fluid Mechanics, vol.41, issue.1, pp.181-202, 2009. ,
DOI : 10.1146/annurev.fluid.010908.165130
A New Divergence Free Synthetic Eddy Method for the Reproduction of Inlet Flow Conditions for LES, Flow, Turbulence and Combustion, vol.23, issue.11, pp.519-539, 2013. ,
DOI : 10.1007/s10494-013-9488-2
Subgrid scale stress models for the large-eddy simulation of rotating turbulent flows, Geophysical & Astrophysical Fluid Dynamics, vol.3, issue.1-4, pp.199-222, 1985. ,
DOI : 10.1080/03091928508245430
New insight into the functional dependence rules in turbulence modelling, International Journal of Engineering Science, vol.46, issue.11, pp.1053-1062, 2008. ,
DOI : 10.1016/j.ijengsci.2008.04.004
On isotropic functions of symmetric tensors, skew-symmetric tensors and vectors, International Journal of Engineering Science, vol.9, issue.10, p.899, 1971. ,
DOI : 10.1016/0020-7225(71)90023-1
Two-equation eddy-viscosity turbulence models for engineering applications, AIAA Journal, vol.32, issue.8, pp.1598-1605, 1994. ,
DOI : 10.2514/3.12149
