New interface
Conference papers
Multiple target tracking under occlusions using modified Joint Probabilistic Data Association
Xiufang Shi 1 Ye-Qiong Song 2 Zaiyue Yang 1 Jiming Chen 1
2 MADYNES - Management of dynamic networks and services
Inria Nancy - Grand Est, LORIA - NSS - Department of Networks, Systems and Services
Abstract : The size of target will induce a degradation of tracking performance, which has been neglected for simplicity in most previous studies. In multiple target tracking, occlusions will be caused by target size effect, one target can become a moving obstacle blocking the direct channel between the anchor and another target. In this paper, the data association problem in multiple target tracking is investigated. To reduce the computational complexity of traditional Joint Probabilistic Data Association (JPDA) algorithm, a modified JPDA algorithm is proposed to execute data association in multiple target tracking by utilizing the information of occlusion conditions, which is identified by a three-step algorithm. Simulation results show that the proposed algorithm is with good tracking performance and low computational complexity.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01246931
Contributor : Ye-Qiong Song Connect in order to contact the contributor
Submitted on : Sunday, December 20, 2015 - 3:36:08 PM
Last modification on : Saturday, June 25, 2022 - 7:39:38 PM
Long-term archiving on: : Saturday, April 29, 2017 - 10:33:18 PM
File
edas.final-1570038319.pdf
Identifiers
Collections
Citation
Xiufang Shi, Ye-Qiong Song, Zaiyue Yang, Jiming Chen. Multiple target tracking under occlusions using modified Joint Probabilistic Data Association. 2015 IEEE International Conference on Communications, ICC 2015, IEEE, Jun 2015, London, United Kingdom. 6 (pp.6615 - 6620), ⟨10.1109/ICC.2015.7249379⟩. ⟨hal-01246931⟩
Share
Metrics
Record views
464
Files downloads
146
