Error bounds of complex arithmetic, 2011. ,
Error bounds on complex floating-point multiplication, Mathematics of Computation, vol.76, issue.259, pp.1469-1481, 2007. ,
DOI : 10.1090/S0025-5718-07-01931-X
URL : https://hal.archives-ouvertes.fr/inria-00120352
Modern Computer Arithmetic, 2010. ,
DOI : 10.1017/CBO9780511921698
URL : https://hal.archives-ouvertes.fr/cel-01500109
Contributions to Computer Arithmetic and Applications to Embedded Systems, 2014. ,
URL : https://hal.archives-ouvertes.fr/tel-01078204
On finding roots of polynomials by hook or by crook, 1964. ,
A Graduate Introduction to Numerical Methods, From the Viewpoint of Backward Error Analysis, 2013. ,
Scientific Computing on Itanium R -based Systems, 2002. ,
A floating-point technique for extending the available precision, Numerische Mathematik, vol.5, issue.3, pp.224-242, 1971. ,
DOI : 10.1007/BF01397083
Applied Numerical Linear Algebra, SIAM, 1997. ,
DOI : 10.1137/1.9781611971446
What every computer scientist should know about floating-point arithmetic, ACM Computing Surveys, vol.23, issue.1, pp.5-48, 1991. ,
DOI : 10.1145/103162.103163
On the maximum relative error when computing integer powers by iterated multiplications in floating-point arithmetic, Numerical Algorithms, vol.52, issue.1, pp.11075-11090, 2015. ,
DOI : 10.1007/s11075-015-9967-8
URL : https://hal.archives-ouvertes.fr/ensl-00945033
Handling floating-point exceptions in numeric programs, ACM Transactions on Programming Languages and Systems, vol.18, issue.2, pp.139-174, 1996. ,
DOI : 10.1145/227699.227701
Accuracy and Stability of Numerical Algorithms. SIAM, Philadelphia , second edn, 2002. ,
2. Floating Point Arithmetic, The Princeton Companion to Applied Mathematics, pp.96-97, 2015. ,
DOI : 10.1137/1.9780898718027.ch2
Floating-Point Arithmetic and Program Correctness Proofs, 1980. ,
A radix-independent error analysis of the Cornea-Harrison-Tang method, to appear in ACM Software; preprint available at https, Trans. Math ,
Error bounds on complex floating-point multiplication with an FMA, to appear in Mathematics of Computation , preprint available at https ,
Further analysis of Kahan???s algorithm for the accurate computation of $2\times 2$ determinants, Mathematics of Computation, vol.82, issue.284, pp.2245-2264, 2013. ,
DOI : 10.1090/S0025-5718-2013-02679-8
A library for symbolic floating-point arithmetic (2015), preprint available at https ,
Sharp error bounds for complex floating-point inversion (2015), preprint available at https ,
Improved Error Bounds for Inner Products in Floating-Point Arithmetic, SIAM Journal on Matrix Analysis and Applications, vol.34, issue.2, pp.338-344, 2013. ,
DOI : 10.1137/120894488
URL : https://hal.archives-ouvertes.fr/hal-00840926
On relative errors of floating-point operations: optimal bounds and applications (2014), preprint available at https ,
Pracniques: further remarks on reducing truncation errors, Communications of the ACM, vol.8, issue.1, p.40, 1965. ,
DOI : 10.1145/363707.363723
The Art of Computer Programming Seminumerical Algorithms, 1998. ,
Quasi double-precision in floating point addition, BIT, vol.7, issue.6, pp.37-50, 1965. ,
DOI : 10.1007/BF01975722
The pitfalls of verifying floating-point computations, ACM Transactions on Programming Languages and Systems, vol.30, issue.3, pp.1-1241, 2008. ,
DOI : 10.1145/1353445.1353446
URL : https://hal.archives-ouvertes.fr/hal-00128124
using Cornea, Harrison and Tang's Method, ACM Transactions on Mathematical Software, vol.41, issue.2, pp.1-78, 2015. ,
DOI : 10.1145/2629615
Handbook of Floating-Point Arithmetic, 2010. ,
DOI : 10.1007/978-0-8176-4705-6
URL : https://hal.archives-ouvertes.fr/ensl-00379167
Accurate Sum and Dot Product, SIAM Journal on Scientific Computing, vol.26, issue.6, pp.1955-1988, 2005. ,
DOI : 10.1137/030601818
Numerical Computing with IEEE Floating Point Arithmetic: Including One Theorem, One Rule of Thumb, and One Hundred and One Exercises, Society for Industrial and Applied Mathematics, 2001. ,
DOI : 10.1137/1.9780898718072
On Properties of Floating Point Arithmetics: Numerical Stability and the Cost of Accurate Computations, 1992. ,
Ultimately Fast Accurate Summation, SIAM Journal on Scientific Computing, vol.31, issue.5, pp.3466-3502, 2009. ,
DOI : 10.1137/080738490
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.153.1673
Error estimation of floating-point summation and dot product, BIT Numerical Mathematics, vol.11, issue.3, pp.201-220, 2012. ,
DOI : 10.1007/s10543-011-0342-4
Accurate Floating-Point Summation Part I: Faithful Rounding, SIAM Journal on Scientific Computing, vol.31, issue.1, pp.189-224, 2008. ,
DOI : 10.1137/050645671
Improved error bounds for floating-point products and Horner???s scheme, BIT Numerical Mathematics, vol.31, issue.1, 2015. ,
DOI : 10.1007/s10543-015-0555-z
URL : https://hal.archives-ouvertes.fr/hal-01137652
Improved Backward Error Bounds for LU and Cholesky Factorizations, SIAM Journal on Matrix Analysis and Applications, vol.35, issue.2, pp.684-698, 2014. ,
DOI : 10.1137/130927231
URL : https://hal.archives-ouvertes.fr/hal-00841361
Floating-Point Computation, 1974. ,
Computing numerically with functions instead of numbers, Communications of the ACM, vol.58, issue.10, pp.9-19, 2007. ,
DOI : 10.1145/2814847
Error analysis of floating-point computation, Numerische Mathematik, vol.3, issue.1, pp.319-340, 1960. ,
DOI : 10.1007/BF01386233
The Algebraic Eigenvalue Problem, 1965. ,
