SCAC-Net: Reconfigurable Interconnection Network in SCAC Massively parallel SoC
Hana Krichene 1, 2 Mouna Baklouti 1 Mohamed Abid 1 Philippe Marquet 2 Jean-Luc Dekeyser 2 Samy Meftali 2
2 DREAMPAL - Dynamic Reconfigurable Massively Parallel Architectures and Languages
Inria Lille - Nord Europe, CRIStAL - Centre de Recherche en Informatique, Signal et Automatique de Lille (CRIStAL) - UMR 9189
Abstract : Parallel communication plays a critical role in massively parallel systems, especially in distributed memory systems executing parallel programs on shared data. Therefore, integrating an interconnection network in these systems becomes essential to ensure data inter-nodes exchange. Choose the most effective communication structure must meet certain criteria: speed, size and power consumption. Indeed, the communication phase should be as fast as possible to avoid compromising parallel computing, using small and low power consumption modules to facilitate the interconnection network extensibility in a scalable system. To meet these criteria and based on a module reuse methodology, we chose to integrate a reconfigurable SCAC-Net interconnection network to communicate data in SCAC Massively parallel SoC. This paper presents the detailed hardware implementation and discusses the performance evaluation of the proposed reconfigurable SCAC-Net network.
Type de document :
Communication dans un congrès
The 24th Euromicro International Conference on Parallel, Distributed and Network-Based Processing, Feb 2016, Heraklion, Greece. The 24th Euromicro International Conference on Parallel, Distributed and Network-Based Processing, 〈www.pdp2016.org〉
Liste complète des métadonnées
Littérature citée [13 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/hal-01247298
Contributeur : Pal Dream <>
Soumis le : lundi 21 décembre 2015 - 16:20:22
Dernière modification le : jeudi 11 janvier 2018 - 02:08:44
Document(s) archivé(s) le : mardi 22 mars 2016 - 13:00:42
Fichier
PDP2016.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : hal-01247298, version 1
Citation
Hana Krichene, Mouna Baklouti, Mohamed Abid, Philippe Marquet, Jean-Luc Dekeyser, et al.. SCAC-Net: Reconfigurable Interconnection Network in SCAC Massively parallel SoC. The 24th Euromicro International Conference on Parallel, Distributed and Network-Based Processing, Feb 2016, Heraklion, Greece. The 24th Euromicro International Conference on Parallel, Distributed and Network-Based Processing, 〈www.pdp2016.org〉. 〈hal-01247298〉
Métriques
Consultations de la notice
208
Téléchargements de fichiers
135
