The local detection paradigm and its applications to self-stabilization, Theoretical Computer Science, vol.186, issue.1-2, pp.199-229, 1997. ,
DOI : 10.1016/S0304-3975(96)00286-1
Labeling Schemes for Small Distances in Trees, 14th ACM-SIAM Symposium on Discrete Algorithms (SODA), pp.689-698, 2003. ,
DOI : 10.1137/S0895480103433409
Nearest common ancestors, Proceedings of the fourteenth annual ACM symposium on Parallel algorithms and architectures , SPAA '02, pp.258-264, 2002. ,
DOI : 10.1145/564870.564914
URL : https://hal.archives-ouvertes.fr/hal-00307617
Small induced-universal graphs and compact implicit graph representations, The 43rd Annual IEEE Symposium on Foundations of Computer Science, 2002. Proceedings., pp.53-62, 2002. ,
DOI : 10.1109/SFCS.2002.1181882
Distributedly Testing Cycle-Freeness, 40th Int. Workshop on Graph-Theoretic Concepts in Computer Science (WG), pp.15-28, 2014. ,
DOI : 10.1007/978-3-319-12340-0_2
URL : https://hal.archives-ouvertes.fr/hal-01084297
Local Decision and Verification with Bounded-Size Outputs, 15th Symp. on Stabilization, Safety, and Security of Distributed Systems (SSS), pp.133-147, 2013. ,
DOI : 10.1007/978-3-319-03089-0_10
URL : https://hal.archives-ouvertes.fr/hal-00922700
Time optimal self-stabilizing synchronization, Proceedings of the twenty-fifth annual ACM symposium on Theory of computing , STOC '93, pp.652-661, 1993. ,
DOI : 10.1145/167088.167256
Self-stabilization by local checking and correction, [1991] Proceedings 32nd Annual Symposium of Foundations of Computer Science, pp.268-277, 1991. ,
DOI : 10.1109/SFCS.1991.185378
On Proof-Labeling Schemes versus Silent Self-stabilizing Algorithms, 16th Int. Symp. on Stabilization, Safety, and Security of Distributed Systems (SSS), pp.18-32, 2014. ,
DOI : 10.1007/978-3-319-11764-5_2
URL : https://hal.archives-ouvertes.fr/hal-01102123
Reachability and Distance Queries via 2-Hop Labels, 13th ACM-SIAM Symposium on Discrete Algorithms (SODA), pp.937-946, 2002. ,
DOI : 10.1137/S0097539702403098
Distributed Verification and Hardness of Distributed Approximation, SIAM Journal on Computing, vol.41, issue.5, pp.1235-1265, 2012. ,
DOI : 10.1137/11085178X
Routing in Trees, 28th International Colloquium on Automata, Languages and Programming (ICALP), pp.757-772, 2001. ,
DOI : 10.1007/3-540-48224-5_62
URL : https://hal.archives-ouvertes.fr/hal-00307398
A Space Lower Bound for Routing in Trees, 19th Symp. on Theoretical Aspects of Computer Science (STACS), pp.65-75, 2002. ,
DOI : 10.1007/3-540-45841-7_4
On randomized representations of graphs using short labels, Proceedings of the twenty-first annual symposium on Parallelism in algorithms and architectures, SPAA '09, pp.131-137, 2009. ,
DOI : 10.1145/1583991.1584031
Towards a complexity theory for local distributed computing, Journal of the ACM, vol.60, issue.5, p.35, 2013. ,
DOI : 10.1145/2499228
Locality and Checkability in Wait-Free Computing, Distributed Computing, vol.15, issue.4, pp.223-242, 2013. ,
DOI : 10.1007/BF01961540
URL : https://hal.archives-ouvertes.fr/hal-00992781
On the Number of Opinions Needed for Fault-Tolerant Run-Time Monitoring in Distributed Systems, 5th International Conference on Runtime Verification (RV), pp.92-107, 2014. ,
DOI : 10.1007/978-3-319-11164-3_9
URL : https://hal.archives-ouvertes.fr/hal-01102121
Approximate distance labeling schemes, 9th European Symposium on Algorithms (ESA), pp.476-487, 2001. ,
Split Decomposition and Distance Labelling: An Optimal Scheme For Distance Hereditary Graphs, Electronic Notes in Discrete Mathematics, vol.10, pp.117-120, 2001. ,
DOI : 10.1016/S1571-0653(04)00374-9
Distance labeling in graphs, 12th ACM Symposium on Discrete Algorithms (SODA), pp.210-219, 2001. ,
DOI : 10.1016/j.jalgor.2004.05.002
URL : https://hal.archives-ouvertes.fr/hal-00307381
Locally checkable proofs, 30th ACM Symp. on Principles of Distributed Computing (PODC), pp.159-168, 2011. ,
Algorithm 447: efficient algorithms for graph manipulation, Communications of the ACM, vol.16, issue.6, pp.372-378, 1973. ,
DOI : 10.1145/362248.362272
Fast and lean self-stabilizing asynchronous protocols, Proceedings 35th Annual Symposium on Foundations of Computer Science, pp.226-239, 1994. ,
DOI : 10.1109/SFCS.1994.365691
Implicit representation of graphs, Proceedings of the twentieth annual ACM symposium on Theory of computing , STOC '88, pp.596-603, 1992. ,
DOI : 10.1145/62212.62244
Short and Simple Labels for Small Distances and Other Functions, 7th Int. Workshop on Algorithms and Data Structures (WADS), pp.246-257, 2001. ,
DOI : 10.1007/3-540-44634-6_23
Labeling Schemes for Flow and Connectivity, 13th ACM-SIAM Symposium on Discrete Algorithms (SODA), pp.927-936, 2002. ,
DOI : 10.1137/S0097539703433912
Distance labeling schemes for well-separated graph classes, Discrete Applied Mathematics, vol.145, issue.3, pp.384-402, 2005. ,
DOI : 10.1016/j.dam.2004.03.005
Labeling schemes for vertex connectivity, ACM Transactions on Algorithms, vol.6, issue.2, p.2010 ,
Distributed verification of minimum spanning trees, Distributed Computing, vol.26, issue.1, pp.253-266, 2007. ,
DOI : 10.1007/s00446-007-0025-1
Fast and compact self stabilizing verification, computation, and fault detection of an MST, 30th Annual ACM Symposium on Principles of Distributed Computing (PODC), pp.311-320, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-01240211
Constructing Labeling Schemes through Universal Matrices, Algorithmica, vol.51, issue.3, pp.641-652, 2010. ,
DOI : 10.1007/s00453-008-9226-7
Communication complexity, 1997. ,
Computational Complexity, 1994. ,
Proximity-Preserving Labeling Schemes and Their Applications, 25th International Workshop Graph- Theoretic Concepts in Computer Science (WG), pp.30-41, 1999. ,
DOI : 10.1007/3-540-46784-X_5
Informative labeling schemes for graphs, Theoretical Computer Science, vol.340, issue.3, pp.577-593, 2005. ,
DOI : 10.1016/j.tcs.2005.03.015
Depth-First Search and Linear Graph Algorithms, SIAM Journal on Computing, vol.1, issue.2, pp.146-160, 1972. ,
DOI : 10.1137/0201010
Compact oracles for reachability and approximate distances in planar digraphs, 42nd Symp. on Foundations of Computer Science (FOCS), pp.242-251, 2001. ,
Compact routing schemes, Proceedings of the thirteenth annual ACM symposium on Parallel algorithms and architectures , SPAA '01, pp.1-10, 2001. ,
DOI : 10.1145/378580.378581
Alice simulates the nodes in V 0 of G(x, x), and Bob simulates the nodes in V 1 of G(y, y). The only communication between Alice and Bob induced by this simulation consists of exchanging the bits that are crossing link ,
G has n nodes, and, by Claim C.2, we have x = y ?? Sym ,
Thus, with probability at least 2/3, both Alice and Bob returns TRUE. Similarly, if x = y, then, with probability at least 2/3, at least one node of G outputs FALSE. Hence, with probability at least 2/3, either Alice, or Bob, or both, returns FALSE. Therefore, the 2-party protocol is correct with probability at least 2/3. In this protocol, Alice and Bob exchange ? bits. If ? = o(log n) then ? = o(log ?) as well since n ? ?, This would be in contradiction with the lower bound in Lemma 3.2. Thus the verification complexity of (p, v) is at least ?(log n) ,
3 For any function k(n), any randomized proof-labeling scheme for (F k , Unif) has verification complexity ?(log k) ,
C is a cycle, i.e., not satisfying the predicate. Therefore, by Theorem 4.7, the verification complexity of (F, acyclicity) is ?(log log n). Hence, since F ? F con , the verification complexity of, ST ) is ?(log log n) ,
