New interface
Conference papers
Node Labels in Local Decision
Abstract : The role of unique node identifiers in network computing is well understood as far as symmetry breaking is concerned. However, the unique identifiers also leak information about the computing environment— in particular, they provide some nodes with information related to the size of the network. It was recently proved that in the context of local decision, there are some decision problems such that (1) they cannot be solved without unique identifiers, and (2) unique node identifiers leak a sufficient amount of information such that the problem becomes solvable (PODC 2013). In this work we give study what is the minimal amount of information that we need to leak from the environment to the nodes in order to solve local decision problems. Our key results are related to scalar oracles f that, for any given n, provide a multiset f (n) of n labels; then the adversary assigns the labels to the n nodes in the network. This is a direct generalisation of the usual assumption of unique node identifiers. We give a complete characterisation of the weakest oracle that leaks at least as much information as the unique identifiers. Our main result is the following dichotomy: we classify scalar oracles as large and small, depending on their asymptotic behaviour, and show that (1) any large oracle is at least as powerful as the unique identifiers in the context of local decision problems, while (2) for any small oracle there are local decision problems that still benefit from unique identifiers.
Complete list of metadata
Cited literature [28 references]  Display  Hide  Download
https://hal.inria.fr/hal-01247355
Contributor : Pierre Fraigniaud Connect in order to contact the contributor
Submitted on : Monday, December 21, 2015 - 5:41:45 PM
Last modification on : Tuesday, May 3, 2022 - 6:26:04 PM
Long-term archiving on: : Saturday, April 29, 2017 - 11:47:41 PM
File
sub-SIROCCO2015.pdf
Identifiers
Collections
Citation
Pierre Fraigniaud, Juho Hirvonen, Jukka Suomela. Node Labels in Local Decision. 22nd International Colloquium on Structural Information and Communication Complexity (SIROCCO), Jul 2015, Montserrat, Spain. pp.589-598, ⟨10.1007/978-3-319-25258-2_3⟩. ⟨hal-01247355⟩
Share
Metrics
Record views
135
Files downloads
109
