What can be computed without communications?, ACM SIGACT News, vol.45, issue.3, pp.82-104, 2014. ,
DOI : 10.1145/2670418.2670440
URL : https://hal.archives-ouvertes.fr/hal-01102110
Distributedly Testing Cycle-Freeness, proc. 40th Int. Work. on Graph-Theoretic Concepts in Computer Science (WG), Springer LNCS, pp.15-28, 2014. ,
DOI : 10.1007/978-3-319-12340-0_2
URL : https://hal.archives-ouvertes.fr/hal-01084297
Elkin: Distributed Graph Coloring: Fundamentals and Recent Developments. Synthesis Lectures on Distributed Computing Theory, 2013. ,
Spanners with Slack, proc. 14th Annual European Symposium on Algorithms (ESA), pp.196-207, 2006. ,
DOI : 10.1007/11841036_20
Distributed algorithms for the Lovász local lemma and graph coloring, proc. 33rd ACM Symp. on Principles of Distributed Computing (PODC), pp.134-143, 2014. ,
Distributed Verification and Hardness of Distributed Approximation, SIAM Journal on Computing, vol.41, issue.5, pp.1235-1265, 2012. ,
DOI : 10.1137/11085178X
Compact routing with slack, Proceedings of the twenty-sixth annual ACM symposium on Principles of distributed computing, PODC '07, pp.81-88, 2007. ,
DOI : 10.1145/1281100.1281114
Anonymous networks, Proceedings of the 2014 ACM symposium on Principles of distributed computing, PODC '14, pp.96-105, 2014. ,
DOI : 10.1145/2611462.2611478
An optimal local approximation algorithm for max-min linear programs, Proceedings of the twenty-first annual symposium on Parallelism in algorithms and architectures, SPAA '09, pp.260-269, 2009. ,
DOI : 10.1145/1583991.1584058
Randomized distributed decision, Distributed Computing, vol.20, issue.2, pp.419-434, 2014. ,
DOI : 10.1007/s00446-014-0211-x
URL : https://hal.archives-ouvertes.fr/hal-01093255
What can be decided locally without identifiers? In proc, 32nd ACM Symp. on Principles of Distributed Computing (PODC), vol.2013, pp.157-165 ,
Peleg: Towards a complexity theory for local distributed computing, J. ACM, vol.60, issue.5, p.35, 2013. ,
Locality and checkability in wait-free computing, Distributed Computing, vol.15, issue.4, pp.223-242, 2013. ,
DOI : 10.1007/s00446-013-0188-x
URL : https://hal.archives-ouvertes.fr/hal-00992781
On the Number of Opinions Needed for Fault-Tolerant Run-Time Monitoring in Distributed Systems, proc. 5th International Conference on Runtime Verification (RV), pp.92-107, 2014. ,
DOI : 10.1007/978-3-319-11164-3_9
URL : https://hal.archives-ouvertes.fr/hal-01102121
What Can Be Observed Locally?, proc. 23rd Int. Symp. on Distributed Computing (DISC), Springer LNCS, pp.243-257, 2009. ,
DOI : 10.1007/978-3-642-04355-0_26
URL : https://hal.archives-ouvertes.fr/hal-00408727
Lower bounds for local approximation, J. ACM, vol.60, issue.5, p.39, 2013. ,
Deterministic Local Algorithms, Unique Identifiers, and Fractional Graph Colouring, proc. 19th Int. Colloquium on Structural Information and Communication Complexity (SIROCCO), Springer LNCS, pp.48-60, 2012. ,
Compact routing with slack in low doubling dimension, Proceedings of the twenty-sixth annual ACM symposium on Principles of distributed computing, PODC '07, pp.71-80, 2007. ,
DOI : 10.1145/1281100.1281113
Proof labeling schemes, Distributed Computing, vol.34, issue.2, pp.215-233, 2010. ,
DOI : 10.1007/s00446-010-0095-3
Viennot: Toward more localized local algorithms: removing assumptions concerning global knowledge, Distributed Computing, vol.26, pp.5-6, 2013. ,
What cannot be computed locally! In proc, 23rd ACM Symp. on Principles of Distributed Computing (PODC), pp.300-309, 2004. ,
What can be approximated locally?, Proceedings of the twentieth annual symposium on Parallelism in algorithms and architectures, SPAA '08, pp.46-54, 2008. ,
DOI : 10.1145/1378533.1378540
Wattenhofer: Leveraging Linial's Locality Limit, proc. 22nd Int. Symp. on Distributed Computing (DISC), pp.394-407, 2008. ,
Coloring unstructured radio networks, proc. 17th ACM Symp. on Parallelism in Algorithms and Architectures (SPAA), pp.39-48, 2005. ,
A Lower Bound on Probabilistic Algorithms for Distributive Ring Coloring, SIAM Journal on Discrete Mathematics, vol.4, issue.3, pp.409-412, 1991. ,
DOI : 10.1137/0404036
What Can be Computed Locally?, SIAM Journal on Computing, vol.24, issue.6, pp.1259-1277, 1995. ,
DOI : 10.1137/S0097539793254571
Distributed Computing: A Locality- Sensitive Approach, SIAM, 2000. ,
DOI : 10.1137/1.9780898719772
Survey of local algorithms, ACM Computing Surveys, vol.45, issue.2, p.24, 2013. ,
DOI : 10.1145/2431211.2431223
