Persistence Theory: From Quiver Representations to Data Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ouvrage (Y Compris Édition Critique Et Traduction) Année : 2015
Persistence theory emerged in the early 2000s as a new theory in the area of applied and computational topology. This book provides a broad and modern view of the subject, including its algebraic, topological, and algorithmic aspects. It also elaborates on applications in data analysis. The level of detail of the exposition has been set so as to keep a survey style, while providing sufficient insights into the proofs so the reader can understand the mechanisms at work.
Fichier non déposé
hal-01247501 , version 1 (22-12-2015)
  • HAL Id : hal-01247501 , version 1
Steve Y. Oudot. Persistence Theory: From Quiver Representations to Data Analysis. American Mathematical Society, 209, pp.218, 2015, Mathematical Surveys and Monographs, 978-1-4704-2545-6. ⟨hal-01247501⟩
1321 Consultations
0 Téléchargements
