Brief announcement: Exploring the Consistency Problem Space - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
We study formally the consistency problem, for replicated shared data, in the Action-Constraint framework (ACF). ACF can describe a large range of application semantics and replication protocols, including optimistic and/or partial replication. ACF is used to decompose the consistency problem into simpler sub-problems. Each is easily understood. Existing algorithms from the literature can be explained as combinations of concrete sub-problem implementations. Using ACF, we design a new serialisation algorithm that does not cause aborts and only needs pairwise agreement (not global consensus).
Mots clés
rep
hal-01248206 , version 1 (24-12-2015)
Nishith Krishna, Marc Shapiro, Karthikeyan Bhargavan. Brief announcement: Exploring the Consistency Problem Space. PODC 2005 - 24th annual ACM symposium on Principles Of Distributed Computing, Jul 2005, Las Vegas, Nevada, United States. pp.168--168, ⟨10.1145/1073814.1073845⟩. ⟨hal-01248206⟩
88 Consultations
0 Téléchargements
