Lazy consistency using loosely synchronized clocks, 16th Symp. on Princ. of Distr. Comp. (PODC), pp.73-82, 1997. ,
Epidemic algorithms in replicated databases, 16th Symp. on Princ. of Database Sys. (PODS), pp.161-172, 1997. ,
DNS and BIND, 2001. ,
Panasync: Dependency tracking among file copies, 9th ACM SIGOPS European Workshop, P. Guedes, pp.7-12, 2000. ,
Version stamps?decentralized version vectors, 22nd Int. Conf. on Dist. Comp. Sys. (ICDCS), pp.544-551, 2002. ,
Data caching issues in an information retrieval system, ACM Trans. Database Syst, vol.15, issue.3, pp.359-384, 1990. ,
Measurements of a distributed file system, 13th Symp. on Op. Sys. Principles (SOSP). Pacific, pp.198-212, 1991. ,
What is a file synchronizer, 4th Int. Conf. on Mobile Computing and Networking (MOBICOM, 1998. ,
The failure and recovery problem for replicated databases, Proceedings of the second annual ACM symposium on Principles of distributed computing , PODC '83, pp.114-122, 1983. ,
DOI : 10.1145/800221.806714
Concurrency control and recovery in database systems Available online from http, 1987. ,
Reliable communication in the presence of failures, ACM Trans. Comput. Syst, vol.5, issue.1, pp.272-314, 1987. ,
Grapevine: An exercise in distributed computing, Commun. ACM, vol.25, issue.4, pp.260-274, 1982. ,
Applying RCS and SCCS. O'Reilly & Associates, 1995. ,
Khazana: An infrastructure for building distributed services, 18th Int. Conf. on Dist. Comp. Sys. (ICDCS), pp.562-571, 1998. ,
Version management with CVS, 2001. ,
End-to-end WAN service availability, 3rd USENIX Symp. on Internet Tech. and Sys. (USITS), 2001. ,
Unreliable failure detectors for reliable distributed systems, Journal of the ACM (JACM), vol.43, issue.2, pp.225-267, 1996. ,
A hierarchical Internet object cache, USENIX Winter Tech. Conf, pp.153-164, 1996. ,
A prototype implementation of Archival Intermemory, Fourth ACM Conf. on Digital Libraries (DL'99, pp.28-37, 1999. ,
Synchronizing a database to improve freshness, Int. Conf. on Management of Data (SIGMOD), pp.117-128, 2000. ,
Fast reconciliations in fluid replication, 21st Int. Conf. on Dist. Comp. Sys. (ICDCS), 2001. ,
Plausible clocks: Constant size logical clocks for distributed systems, 10th Int. Workshop on Dist. Algorithms (WDAG), 1996. ,
Multicast routing in a datagram internetwork Epidemic algorithms for replicated database maintenance, 6th Symp. on Princ. of Distr. Comp. (PODC), pp.1-12, 1987. ,
Concurrency control in groupware systems, Int. Conf. on Management of Data (SIGMOD), 1989. ,
Database transaction models for advanced applications, 1992. ,
Fine-grained network time synchronization using reference broadcasts, 5th Symp. on Op. Sys. Design and Impl. (OSDI), 2002. ,
Eventually serializable data services, Theoretical Computer Science, vol.220, pp.113-156, 1999. ,
Specifying and using a partitionable group communication service, 16th Symp. on Princ. of Distr. Comp. (PODC), pp.53-62, 1997. ,
RFC2616: Hypertext transfer protocol ? HTTP/1.1, 1999. ,
Impossibility of distributed consensus with one faulty process, Journal of the ACM (JACM), vol.32, issue.2, pp.374-382, 1985. ,
Sacrificing serializability to attain availability of data in an unreliable network, 1st Symp. on Princ. of Database Sys. (PODS), pp.70-75, 1982. ,
A reliable multicast framework for light-weight sessions and application level framing, IEEE/ACM Journal on Networking, vol.5, issue.6, pp.784-803, 1997. ,
Harvest, yield, and scalable tolerant systems, 6th Workshop on Hot Topics in Operating Systems (HOTOS-VI), pp.174-178, 1999. ,
Dangers of replication and a solution, Int. Conf. on Management of Data (SIGMOD), pp.173-182, 1996. ,
Transaction processing: Concepts and techniques, 1993. ,
Consistency algorithms for optimistic replication, Proc. First IEEE Int. Conf. on Network Protocols, 1993. ,
A survey of gossiping and broadcasting in communication networks, pp.319-349, 1988. ,
Linearizability: A correctness condition for concurrent objects, ACM Trans. Program. Lang. Syst, vol.12, issue.3, pp.463-492, 1990. ,
Scalable versioning in distributed databases with commuting updates, 13th Int. Conf. on Data Eng. (ICDE), pp.520-531, 1997. ,
RFC677: The maintenance of duplicate databases, 1976. ,
Hierarchical matrix timestamps for scalable update propagation, 1996. ,
The hash history approach for reconciling mutual inconsistency, 23rd Int. Conf. on Dist. Comp. Sys. (ICDCS). Providence, 2003. ,
RFC977: Network news transfer protocol, 1986. ,
Replicated document management in a group communication system, Conf. on Comp.-Supported Coop. Work (CSCW). Chapel Hill, 1988. ,
Spatial gossip and resource location protocols, 33rd Symp. on Theory of Computing (STOC). Crete, Greece, 2001. ,
The IceCube approach to the reconciliation of diverging replicas, 20th Symp. on Princ. of Distr. Comp. (PODC), 2001. ,
Safety, visibility, and performance in a wide-area file system, USENIX Conf. on File and Storage Technologies (FAST). Usenix, 2002. ,
Disconnected operation in the Coda file system, ACM Trans. Comput. Syst, vol.10, issue.5, pp.3-25, 1992. ,
Leafnode: An NNTP server for small sites Bounded ignorance: A technique for increasing concurrency in replicated systems, ACM Trans. Database Syst, vol.19, issue.4, pp.685-722, 1994. ,
Semantic based transaction management techniques for replicated data, Int. Conf. on Management of Data (SIGMOD), pp.117-125, 1988. ,
An analysis of borrowing policies for escrow transactions in a replicated environment, 6th Int. Conf. on Data Eng. (ICDE), pp.446-454, 1990. ,
Log-based directory resolution in the Coda file system, 2nd Int. Conf. on Parallel and Dist. Info. Sys. (PDIS), pp.202-213, 1993. ,
Flexible and safe resolution of file conflicts, USENIX Winter Tech. Conf, pp.95-106, 1995. ,
Lazy replication: Exploiting the semantics of distributed services, 1990. ,
Providing high availability using lazy replication, ACM Trans. Comput. Syst, vol.10, issue.4, pp.360-391, 1992. ,
Optimising synchronisation times for mobile devices, Advances in Neural Information Processing Systems, pp.1401-1408, 2002. ,
Operation shipping for mobile file systems, IEEE Trans. Comput, vol.51, issue.12, pp.1410-1422, 2002. ,
Drinking from the firehose: Multicast USENET news, USENIX Winter Tech. Conf, pp.33-45, 1994. ,
Directional gossip: Gossip in a wide-area network, Third European Dependable Computing Conference, pp.364-379, 1999. ,
Improving data consistency in mobile computing using isolationonly transactions, 4th Workshop on Hot Topics in Operating Systems (HOTOS-IV). Orcas Island, 1995. ,
Building secure file systems out of Byzantine storage, 21st Symp. on Princ. of Distr. Comp. (PODC), 2002. ,
Set reconciliation with nearly optimal communication complexity, International Symposium on Information Theory, 2001. ,
Implementing fault-tolerant replicated objects using Psync, 8th Symp. on Reliable Dist. Sys. (SRDS), pp.42-53, 1989. ,
Development of the Domain Name System, ACM SIGCOMM, pp.123-133, 1988. ,
Safe generic data synchronizer, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00107740
Exploiting weak connectivity for mobile file access, 15th Symp. on Op. Sys. Principles (SOSP). Copper, pp.143-155, 1995. ,
A low-bandwidth network file system, 18th Symp. on Op. Sys. Principles (SOSP). Lake, pp.174-187, 2001. ,
Oracle A trace-driven analysis of the Unix 4.2 BSD file system, Oracle 1996. Oracle7 server distributed systems manual 10th Symp. on Op. Sys. Principles (SOSP). Orcas Island, pp.15-24, 1985. ,
Operation transforms for a distributed shared spreadsheet, Conf. on Comp.-Supported Coop. Work (CSCW), pp.69-78, 1998. ,
Detection of mutual inconsistency in distributed systems, IEEE Trans. Softw. Eng, vol.9, issue.3, pp.240-247, 1983. ,
Reliable multicast transport protocol (RMTP), IEEE Journal on Selected Areas in Communications, vol.15, issue.3, pp.407-421, 1997. ,
Flexible update propagation for weakly consistent replication, 16th Symp. on Op. Sys. Principles (SOSP). St, pp.288-301, 1997. ,
Semantics-based reconciliation for collaborative and environments, Proc. Tenth Int. Conf. on Cooperative Information Systems (CoopIS). Catania, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00445758
Divergence control for distributed database systems, Distributed and Parallel Databases, vol.3, issue.1, pp.85-109, 1995. ,
Divergence control for distributed database systems, Dist. and Parallel Databases, vol.3, issue.1, pp.85-109, 1995. ,
Replica control in distributed systems: An asynchronous approach, Int. Conf. on Management of Data (SIGMOD), pp.377-386, 1991. ,
Fingerprinting by random polynomials Efficient update propagation in epidemic replicated databases, Int. Conf. on Extending Database Technology (EDBT), pp.207-222, 1981. ,
Executive briefing: Advances in concurrency control and transaction processing, 1996. ,
A formal characterization of epsilon serializability, IEEE Trans. on Knowledge and Data Eng, vol.7, issue.6, pp.997-1007, 1995. ,
An algebraic approach to file synchronization, 9th Int. Symp. on the Foundations of Softw. Eng. (FSE). Austria, 2001. ,
Dynamic version vector maintenance, 1997. ,
Using and managing UUCP, 1996. ,
Resolving file conflicts in the Ficus file system, USENIX Summer Tech. Conf, pp.183-195, 1994. ,
Palm programming: The developer's guide. O'Reilly & Associates, 1998. ,
Optimistic Replication for Internet Data Services, 14th Int. Conf. on Dist. Computing (DISC), pp.297-314, 2000. ,
DOI : 10.1007/3-540-40026-5_20
A Usenet performance study, 1998. ,
Managing Usenet. O'Reilly & Associates, 1998. ,
Dealing with server corruption in weakly consistent, replicated data systems, 3rd Int. Conf. on Mobile Computing and Networking (MOBICOM), 1997. ,
A protocol-independent technique for eliminating redundant network traffic, ACM SIGCOMM, 2000. ,
Operational transformation in real-time group editors: Issues, algorithms, and achievements, Conf. on Comp.-Supported Coop. Work (CSCW), pp.59-68, 1998. ,
Achieving convergence, causality-preservation, and intention-preservation in real-time cooperative editing systems, ACM Transactions on Computer-Human Interaction, vol.5, issue.1, pp.63-108, 1998. ,
A consistency model and supporting schemes for realtime cooperative editing systems, 19th Australian Computer Science Conference, pp.582-591, 1996. ,
Session guarantees for weakly consistent replicated data, 3rd Int. Conf. on Parallel and Dist. Info. Sys. (PDIS), pp.140-149, 1994. ,
An examination of conflicts in a weakly-consistent, replicated application, 2000. ,
Managing update conflicts in Bayou, a weakly connected replicated storage system, 15th Symp. on Op. Sys. Principles (SOSP). Copper, pp.172-183, 1995. ,
Copies convergence in a distributed real-time collaborative environment, Conf. on Comp.-Supported Coop. Work (CSCW), pp.171-180, 2000. ,
URL : https://hal.archives-ouvertes.fr/hal-00684563
The LOCUS distributed operating system, 9th Symp. on Op. Sys. Principles (SOSP), pp.49-70, 1983. ,
Understanding the conflict rate metric for peer optimistically replicated filing environments, 2001. ,
RFC2186: Internet Cache Protocol, 1997. ,
Efficient solutions to the replicated log and dictionary problems, 3rd Symp. on Princ. of Distr. Comp. (PODC), pp.233-242, 1984. ,
Hierarchical cache consistency in a WAN, 2nd USENIX Symp. on Internet Tech. and Sys. (USITS), pp.13-24, 1999. ,
Design and evaluation of a continuous consistency model for replicated services, 4th Symp. on Op. Sys. Design and Impl. (OSDI), pp.305-318, 2000. ,
The costs and limits of availability for replicated services, 18th Symp. on Op. Sys. Principles (SOSP). Lake, pp.29-42, 2001. ,
Minimal replication cost for availability, 21st Symp. on Princ. of Distr. Comp. (PODC), pp.98-107, 2002. ,
The stationarity of Internet path properties: Routing, loss and throughput, 2000. ,
