New interface
Reports (Research report)
Efficient semantics-aware reconciliation for optimistic write sharing
Abstract : The IceCube system provides near-optimal reconciliation for optimistically-replicated data. Optimistic replication lets multiple users write to shared data with no remote synchronisation, thus allowing decentralised access immune to network latency and isolation. However such replicas diverge and must be reconciled. Reconciliation depends on the semantics of the shared data and the intents of the users. In IceCube, both applications and shared data types advertise the true dependencies between update actions. IceCube suggests reconciliation schedules that respect these dependencies, using a heuristic search algorithm. IceCube is an application-independent system that enables seamless reconciliation across diverse applications and data types. It has a simple, high-level API that can express a wide range of semantics. It drastically simplifies the development of a reconcilable application. This paper presents the IceCube system in depth and reports on application experience. Evaluation using realistic benchmarks indicates that IceCube runs at reasonable speeds and scales to large input sets.
Keywords : fic rep syn optim
Document type :
Complete list of metadata
https://hal.inria.fr/hal-01248214
Contributor : Alain Monteil Connect in order to contact the contributor
Submitted on : Thursday, December 24, 2015 - 9:43:26 AM
Last modification on : Friday, November 18, 2022 - 9:26:59 AM
Identifiers
  • HAL Id : hal-01248214, version 1
Citation
Nuno Preguiça, Marc Shapiro, Caroline Matheson. Efficient semantics-aware reconciliation for optimistic write sharing. [Research Report] MSR-TR-2002-52, Microsoft Research. 2002. ⟨hal-01248214⟩
Share
Metrics
Record views
49
