Modelling a Distributed Cached Store for Garbage Collection: the algorithm and its correctness proof - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
Paulo Ferreira
Marc Shapiro
Caching and persistence support efficient, convenient and transparent distributed data sharing. The most natural model of persistence is persistence by reachability, managed automatically by a garbage collector (GC). We propose a very general model of such a system (based on distributed shared memory) and a scalable, asynchronous distributed GC algorithm. Within this model, we show sufficient and widely applicable correctness conditions for the interactions between applications, store, memory, coherence, and GC. The GC runs as a set of processes (local to each participating machine) communicating by asynchronous messages. Collection does not interfere with applications by setting locks, polluting caches, or causing I/O; this requirement raised some novel and interesting challenges which we address in this article. The algorithm is safe and live; it is not complete, i.e. it collects some distributed cycles of garbage but not necessarily all.
Mots clés
MDCSGC_ecoop98.pdf (298.75 Ko) Télécharger le fichier
hal-01248219 , version 1 (24-12-2015)
Paulo Ferreira, Marc Shapiro. Modelling a Distributed Cached Store for Garbage Collection: the algorithm and its correctness proof. Euro. Conf. on Object-Oriented Pging. (ECOOP), 1998, Brussels, Belgium. pp.234--259, ⟨10.1007/BFb0054094⟩. ⟨hal-01248219⟩
Collections
INRIA INRIA2
244 Consultations
126 Téléchargements
