Principes de conception du syst eme d'exploitation r eparti Guide, 1987. ,
An overview of the Gothic distributed operating system, 1986. ,
Implementing Remote Procedure Calls, ACM Transactions on Programming Languages and Systems, vol.2, issue.1, 1984. ,
QuickSilver distributed le services: An architecture for horizontal growth, IBM Almaden Research Center, 1987. ,
Principles of object-oriented operating system design, 1989. ,
The Amber system: Parallel programming on a network of multiprocessors, 1989. ,
Decentralizing a global naming service for improved performance and fault tolerance, ACM Transactions on Computer Systems, vol.7, issue.2, pp.147-183, 1989. ,
The V-Kernel, a software base for distributed systems, IEEE Software, vol.1, issue.2, pp.19-42, 1984. ,
Guide : Un syst eme r eparti a objets, Actes Convention Unix 89, pp.297-316, 1989. ,
The Common Lisp Object System, AI Expert, pp.54-65, 1989. ,
Two extensions to C++: A dynamic link editor and inner data, Proceeding and additional papers, C++ Workshop, 1987. ,
URL : https://hal.archives-ouvertes.fr/inria-00444597
Smalltalk-80: The Language and its Implementation, 1983. ,
Reliable broadcast protocols, 1988. ,
Fine-grained mobility in the Emerald system, ACM Transactions on Computer Systems, vol.6, issue.1, pp.109-133, 1988. ,
DOI : 10.1145/35037.42182
The SOS object-oriented communication service, Proc. 9th Int. Conf. on Computer Communication, 1988. ,
URL : https://hal.archives-ouvertes.fr/hal-01248233
Invocations d'objets distants dans SOS, De Nouvelles Architectures pour les Communications, 1988. ,
Protocoles de communication et programmation par objets : l'exemple de SOS, 1989. ,
Clouds: a fault-tolerant distributed operating system, IEEE Tech. Com. Distributed Processing Newsletter, issue.26, 1985. ,
Reusability: The Case for Object-Oriented Design, IEEE Software, vol.4, issue.2, pp.50-63, 1987. ,
DOI : 10.1109/MS.1987.230097
The Design of a Capability-Based Distributed Operating System, The Computer Journal, vol.29, issue.4, pp.289-299, 1986. ,
DOI : 10.1093/comjnl/29.4.289
Plan 9 from Bell Labs { the network, EUUG Spring '88, pp.15-21, 1988. ,
Persistence and migration for C++ objects, 1989. ,
URL : https://hal.archives-ouvertes.fr/inria-00444602
Structure and encapsulation in distributed systems: the Proxy Principle, Proc. 6th Intl. Conf. on Distributed Computing SystemsUSA), 1986. ,
URL : https://hal.archives-ouvertes.fr/inria-00444651
Prototyping a distributed object-oriented OS on Unix, Workshop on Experiences with Building Distributed and Multiprocessor Systems, Ft. Lauderdale FL (USA) USENIX. Also available as Rapport de Recherche INRIA 1082 SOR. Programmer's manual for SOS prototype{version 4. Rapport Technique 103, 1988. ,
URL : https://hal.archives-ouvertes.fr/inria-00444604
SOS reference manual for prototype V4, 1989. ,
URL : https://hal.archives-ouvertes.fr/inria-00070058
Performing remote operations eeciently on a local computer network, pp.246-260, 1982. ,
A set of C++ classes for co-routine style programming, Proceedings and Additional Papers, C++ Workshop, 1987. ,
The C++ Programming Language, 1985. ,
