A General Optimal Multiple Stopping Problem with an Application to Swing Options - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastic Analysis and Applications Année : 2015
In their paper, Carmona and Touzi [8] studied an optimal multiple stopping time problem in a market where the price process is continuous. In this article, we generalize their results when the price process is allowed to jump. Also, we generalize the problem associated to the valuation of swing options to the context of jump diffusion processes. We relate our problem to a sequence of ordinary stopping time problems. We characterize the value function of each ordinary stopping time problem as the unique viscosity solution of the associated Hamilton–Jacobi–Bellman variational inequality.
A_general_optimal_multiple_stopping_problem_with_an_application_to_Swing_Options_final.pdf (326.54 Ko) Télécharger le fichier
hal-01248283 , version 1 (28-12-2015)
Imene Ben Latifa, Joseph Frédéric Bonnans, Mohamed Mnif. A General Optimal Multiple Stopping Problem with an Application to Swing Options. Stochastic Analysis and Applications, 2015, 33 (4), pp.715-739. ⟨10.1080/07362994.2015.1037592⟩. ⟨hal-01248283⟩
149 Consultations
417 Téléchargements
