The two-machine flowshop total completion time problem: A branch-and-bound based on Network-flow formulation
We consider the flowshop problem on two machines with sequence-independent setup times to minimize total completion time. Large scale network flow formulations of the problem are suggested together with strong Lagrangian bounds based on these formulations. To cope with their size, filtering procedures are developed. To solve the problem to optimality, we embed the Lagrangian bounds into two branch-and- bound algorithms. The best algorithm is able to solve all 100-jobs instances of our testbed with and without setup times, thus significantly outperforming the best algorithms in the literature.
Recherche opérationnelle [math.OC]
