A new Lagrangian bound for the min-sum job-shop scheduling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This study will propose a new Lagrangian bound for the min-sum job-shop scheduling problem. The proposed method is an integration of two types of Lagrangian relaxation methods known as job-level and machine-level decomposition methods. It will be shown by numerical experiments that the proposed method can improve the existing lower bounds significantly.
Tanaka_etall_ISS15.pdf (61.72 Ko) Télécharger le fichier
hal-01248322 , version 1 (24-12-2015)
  • HAL Id : hal-01248322 , version 1
Shunji Tanaka, Ruslan Sadykov, Boris Detienne. A new Lagrangian bound for the min-sum job-shop scheduling. International Symposium on Scheduling ISS'2015, Jul 2015, Kobe, Japan. ⟨hal-01248322⟩
165 Consultations
130 Téléchargements
