Algorithms in Real Algebraic Geometry, Algorithms and Computation in Mathematics, vol.10, 2006. ,
DOI : 10.1007/978-3-662-05355-3
URL : https://hal.archives-ouvertes.fr/hal-01083587
Long Integers and Polynomial Evaluation with Estrin's Scheme, 2011 13th International Symposium on Symbolic and Numeric Algorithms for Scientific Computing, pp.39-46, 2011. ,
DOI : 10.1109/SYNASC.2011.17
Real Root Isolation of Regular Chains, Proc. Asian Symposium on Computer Mathematics (ASCM), pp.1-15, 2009. ,
DOI : 10.1007/978-3-662-43799-5_4
URL : https://hal.archives-ouvertes.fr/hal-00825036
Separating linear forms and rational univariate representations of bivariate systems URL https, Journal of Symbolic Computation, pp.84-119, 2015. ,
DOI : 10.1016/j.jsc.2014.08.009
Complete numerical isolation of real roots in zero-dimensional triangular systems, Journal of Symbolic Computation, vol.44, issue.7, pp.768-785, 2009. ,
DOI : 10.1016/j.jsc.2008.04.017
Polynomial real root isolation using Descartes' rule of signs, SYMSAC '76, pp.272-275, 1976. ,
DOI : 10.1145/800205.806346
Polynomial real root isolation by differentiation, Proceedings of the third ACM symposium on Symbolic and algebraic computation , SYMSAC '76, pp.15-25, 1976. ,
DOI : 10.1145/800205.806319
Cylindrical algebraic decomposition, School of Mathematical Sciences, 1988. ,
On the asymptotic and practical complexity of solving bivariate systems over the reals, Journal of Symbolic Computation, vol.44, issue.7, pp.818-835, 2009. ,
DOI : 10.1016/j.jsc.2008.04.009
Amortized Bound for Root Isolation via Sturm Sequences, Int. Workshop on Symbolic Numeric Computing, pp.113-129, 2005. ,
DOI : 10.1007/978-3-7643-7984-1_8
Real root isolation for exact and approximate polynomials using Descartes´ruleDescartes´rule of signs, 2008. ,
A Descartes Algorithm for Polynomials with Bit-Stream Coefficients, LNCS, vol.3718, pp.138-149, 2005. ,
DOI : 10.1007/11555964_12
Almost tight recursion tree bounds for the Descartes method, Proceedings of the 2006 international symposium on Symbolic and algebraic computation , ISSAC '06, pp.71-78, 2006. ,
DOI : 10.1145/1145768.1145786
URL : http://domino.mpi-inf.mpg.de/intranet/ag1/ag1publ.nsf/AuthorEditorIndividualView/6e09cb7fbe62ea64c12571b20040a5d4/$FILE/ESY-DescTree-ISSAC06-authprep.pdf?OpenElement
Real Algebraic Numbers: Complexity Analysis and Experimentation Reliable Implementations of Real Number Algorithms: Theory and Practice, LNCS, vol.5045, pp.57-82, 2008. ,
On the davenport-mahler bound. arXiv preprint, 2016. ,
DOI : 10.1016/j.jco.2016.12.001
Practical Divide-and-Conquer Algorithms for Polynomial Arithmetic, Proc. CASC, pp.200-214, 2011. ,
DOI : 10.1007/978-1-4612-0129-8
URL : https://hal.archives-ouvertes.fr/hal-00650389
Polynomial real root isolation using approximate arithmetic, Proceedings of the 1997 international symposium on Symbolic and algebraic computation , ISSAC '97, pp.225-232, 1997. ,
DOI : 10.1145/258726.258790
URL : http://www.uni-paderborn.de/cs/ag-monien/PERSONAL/KRANDICK/papers/issac97.ps.Z
Algorithms for Polynomial Real Root Isolation, 1991. ,
DOI : 10.1007/978-3-7091-9459-1_13
Sylvester???Habicht Sequences and Fast Cauchy Index Computation, Journal of Symbolic Computation, vol.31, issue.3, pp.315-341, 2001. ,
DOI : 10.1006/jsco.2000.0427
URL : https://doi.org/10.1006/jsco.2000.0427
Computing in algebraic extensions, Computer Algebra: Symbolic and Algebraic Computation, pp.173-187, 1983. ,
DOI : 10.1007/978-3-7091-3406-1_12
An algorithm of real root isolation for polynomial system, Proc. 1st ACM Int'l Work. Symbolic Numeric Computation (SNC), pp.94-107, 2005. ,
A deterministic algorithm for isolating real roots of a real polynomial, Journal of Symbolic Computation, vol.46, issue.1, pp.70-90, 2011. ,
DOI : 10.1016/j.jsc.2010.09.004
From approximate factorization to root isolation with application to cylindrical algebraic decomposition, Journal of Symbolic Computation, vol.66, issue.0, pp.34-69, 2015. ,
DOI : 10.1016/j.jsc.2014.02.001
URL : http://arxiv.org/pdf/1301.4870
Mathematics for Computer Algebra, 1991. ,
DOI : 10.1007/978-1-4613-9171-5
On the Complexity of Isolating Real Roots and Computing with Certainty the Topological Degree, Journal of Complexity, vol.18, issue.2, 2002. ,
DOI : 10.1006/jcom.2001.0636
Approximating Complex Polynomial Zeros: Modified Weyl's Quadtree Construction and Improved Newton's Iteration, Journal of Complexity, vol.16, issue.1, pp.213-264, 2000. ,
DOI : 10.1006/jcom.1999.0532
URL : https://doi.org/10.1006/jcom.1999.0532
Univariate polynomials, Proceedings of the 2001 international symposium on Symbolic and algebraic computation , ISSAC '01, pp.701-733, 2002. ,
DOI : 10.1145/384101.384136
Nearly Optimal Computations with Structured Matrices, Proceedings of the 2014 Symposium on Symbolic-Numeric Computation, pp.21-30, 2014. ,
DOI : 10.1145/2631948.2631954
URL : https://hal.archives-ouvertes.fr/hal-00980591
Nearly optimal refinement of real roots of a univariate polynomial, Journal of Symbolic Computation, vol.74, 2014. ,
DOI : 10.1016/j.jsc.2015.06.009
URL : https://hal.archives-ouvertes.fr/hal-00960896
Nearly optimal computations with structured matrices (journal version) URL https, 2015. ,
On the boolean complexity of real root refinement, Proceedings of the 38th international symposium on International symposium on symbolic and algebraic computation, ISSAC '13, pp.299-306, 2013. ,
DOI : 10.1145/2465506.2465938
URL : https://hal.archives-ouvertes.fr/hal-00816214
Change of order for bivariate triangular sets, Proceedings of the 2006 international symposium on Symbolic and algebraic computation , ISSAC '06, pp.277-284, 2006. ,
DOI : 10.1145/1145768.1145814
Towards faster real algebraic numbers, Journal of Symbolic Computation, vol.36, issue.3-4, pp.513-533, 2003. ,
DOI : 10.1016/S0747-7171(03)00093-2
URL : https://hal.archives-ouvertes.fr/hal-01199502
Efficient isolation of polynomial's real roots, Journal of Computational and Applied Mathematics, vol.162, issue.1, pp.33-50, 2004. ,
DOI : 10.1016/j.cam.2003.08.015
On the sign of a real algebraic number, Proceedings of the third ACM symposium on Symbolic and algebraic computation , SYMSAC '76, pp.238-241, 1976. ,
DOI : 10.1145/800205.806341
Real root isolation for algebraic polynomials, ACM SIGSAM Bulletin, vol.11, issue.2, pp.327-336, 1977. ,
DOI : 10.1145/1088240.1088241
On the complexity of real root isolation. CoRR, abs, 1011. ,
When Newton meets Descartes, Proceedings of the 37th International Symposium on Symbolic and Algebraic Computation, ISSAC '12, pp.297-304, 2012. ,
DOI : 10.1145/2442829.2442872
The fundamental theorem of algebra in terms of computational complexity, Manuscript. Univ. of Tübingen, 1982. ,
Univariate real root isolation in an extension field, Proc. 36th ACM Int'l Symp. on Symbolic & Algebraic Comp. (ISSAC), pp.321-328, 2011. ,
On the complexity of real root isolation using continued fractions, Theoretical Computer Science, vol.392, issue.1-3, pp.158-173, 2008. ,
DOI : 10.1016/j.tcs.2007.10.010
URL : https://hal.archives-ouvertes.fr/inria-00116990
A modular GCD algorithm over number fields presented with multiple extensions, Proceedings of the 2002 international symposium on Symbolic and algebraic computation , ISSAC '02, pp.109-116, 2002. ,
DOI : 10.1145/780506.780520
An Algorithm for Isolating the Real Solutions of Semi-algebraic Systems, Journal of Symbolic Computation, vol.34, issue.5, pp.461-477, 2002. ,
DOI : 10.1006/jsco.2002.0572
Real solution isolation using interval arithmetic, Computers & Mathematics with Applications, vol.52, issue.6-7, pp.853-860, 2006. ,
DOI : 10.1016/j.camwa.2006.06.003
URL : https://doi.org/10.1016/j.camwa.2006.06.003
Fundamental Problems of Algorithmic Algebra, 2000. ,
