STRING v10: protein-protein interaction networks, integrated over the tree of life, Nucleic Acids Research, vol.43, issue.D1, p.43, 2015. ,
DOI : 10.1093/nar/gku1003
Modeling cellular machinery through biological network comparison, Nature Biotechnology, vol.42, issue.4, pp.427-433, 2006. ,
DOI : 10.1038/nbt1196
From genomics to chemical genomics: new developments in KEGG, Nucleic Acids Research, vol.34, issue.90001, 2006. ,
DOI : 10.1093/nar/gkj102
URL : http://doi.org/10.1093/nar/gkj102
Network motifs: theory and experimental approaches, Nature Reviews Genetics, vol.301, issue.6, pp.450-461, 2007. ,
DOI : 10.1038/nrg2102
Global Alignment of Protein-Protein Interaction Networks: A Survey, IEEE/ACM Transactions on Computational Biology and Bioinformatics, vol.13, issue.4, 2015. ,
DOI : 10.1109/TCBB.2015.2474391
Global alignment of multiple protein interaction networks with application to functional orthology detection, Proc. Natl. Acad. Sci, pp.12763-12768, 2008. ,
DOI : 10.1073/pnas.0307326101
A new graph-based method for pairwise global network alignment, BMC Bioinformatics, vol.10, issue.Suppl 1, 2009. ,
DOI : 10.1186/1471-2105-10-S1-S59
URL : http://doi.org/10.1186/1471-2105-10-s1-s59
Topological network alignment uncovers biological function and phylogeny, Journal of The Royal Society Interface, vol.25, issue.12, pp.1341-54, 2010. ,
DOI : 10.1093/bioinformatics/btp196
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC2894889
Global network alignment using multiscale spectral signatures, Bioinformatics, vol.28, issue.23, pp.3105-3114 ,
DOI : 10.1093/bioinformatics/bts592
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC3509496
NETAL: a new graph-based method for global alignment of protein-protein interaction networks, Bioinformatics, vol.29, issue.13, pp.1654-1662, 2013. ,
DOI : 10.1093/bioinformatics/btt202
SPINAL: Scalable protein interaction network alignment, Bioinformatics 2013, vol.29, pp.917-924 ,
Optimizing a global alignment of protein interaction networks, Bioinformatics, vol.29, issue.21, pp.2765-2773 ,
DOI : 10.1093/bioinformatics/btt486
HubAlign: an accurate and efficient method for global alignment of protein???protein interaction networks, Bioinformatics, vol.30, issue.17, pp.438-444, 2014. ,
DOI : 10.1093/bioinformatics/btu450
MAGNA++: Maximizing Accuracy in Global Network Alignment via both node and edge conservation, Bioinformatics, vol.31, issue.14, 2015. ,
DOI : 10.1093/bioinformatics/btv161
A multiobjective memetic algorithm for PPI network alignment, Bioinformatics, vol.31, issue.12, 1988. ,
DOI : 10.1093/bioinformatics/btv063
L-GRAAL: Lagrangian graphlet-based network aligner, Bioinformatics, vol.31, issue.13, pp.2182-2189, 2015. ,
DOI : 10.1093/bioinformatics/btv130
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC4481854
NatalieQ: A web server for protein-protein interaction network querying, BMC Systems Biology, vol.8, issue.1, pp.10-1186 ,
DOI : 10.1093/bioinformatics/btq675
URL : http://doi.org/10.1186/1752-0509-8-40
Reducibility Among Combinatorial Problems, Complexity of Computer Computations, pp.85-103, 1972. ,
DOI : 10.1007/978-1-4684-2001-2_9
The Quadratic Assignment Problem, Management Science, vol.9, issue.4, pp.586-599 ,
DOI : 10.1287/mnsc.9.4.586
Improved linear programming-based lower
bounds for the quadratic assignment problem, DIMACS Ser. Discr. Math. Theor. Comput. Sci, vol.16, pp.43-77, 1994. ,
DOI : 10.1090/dimacs/016/02
The Hungarian method for the assignment problem, Naval Research Logistics Quarterly, vol.3, issue.1-2, pp.83-97, 1955. ,
DOI : 10.1002/nav.3800020109
Algorithms for the Assignment and Transportation Problems, Journal of the Society for Industrial and Applied Mathematics, vol.5, issue.1, pp.32-38, 1957. ,
DOI : 10.1137/0105003
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.228.3911
Theoretical Improvements in Algorithmic Efficiency for Network Flow Problems, Journal of the ACM, vol.19, issue.2, pp.248-264 ,
DOI : 10.1145/321694.321699
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.228.3560
Path, trees, and flowers. Can, J Math, vol.17, pp.449-467, 1965. ,
Lagrangean relaxation, Top, vol.4, issue.2, pp.151-200, 2003. ,
DOI : 10.1007/BF02579036
The traveling-salesman problem and minimum spanning trees: Part II, Mathematical Programming, vol.6, issue.1, pp.6-25, 1971. ,
DOI : 10.1007/BF01584070
A Heuristic Method for the Set Covering Problem, Operations Research, vol.47, issue.5, pp.730-743, 1999. ,
DOI : 10.1287/opre.47.5.730
Tool for the unification of biology, Nat. Genet, vol.25, pp.25-29, 2000. ,
Measuring semantic similarity between Gene Ontology terms, Data & Knowledge Engineering, vol.61, issue.1, pp.61-137, 2007. ,
DOI : 10.1016/j.datak.2006.05.003
Algorithm engineering for optimal alignment of protein structure distance matrices, Optimization Letters, vol.14, issue.5, pp.421-433, 2011. ,
DOI : 10.1007/s11590-011-0313-3
URL : https://hal.archives-ouvertes.fr/inria-00586067
