Positivity-preserving cell-centered Lagrangian schemes for multi-material compressible flows: From first-order to high-orders. Part II: The two-dimensional case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2016
This paper is the second part of a series of two. It follows [44], in which the positivity-preservation property of methods solving one-dimensional Lagrangian gas dynamics equations, from first-order to high-orders of accuracy, was addressed. This article aims at extending this analysis to the two-dimensional case. This study is performed on a general first-order cell-centered finite volume formulation based on polygonal meshes defined either by straight line edges, conical edges, or any high-order curvilinear edges. Such formulation covers the numerical methods introduced in [6, 32, 5, 41, 43]. This positivity study is then extended to high-orders of accuracy. Through this new procedure, scheme robustness is highly improved and hence new problems can be tackled. Numerical results are provided to demonstrate the effectiveness of these methods. It important to point out that even if this paper is concerned with purely Lagrangian schemes, the theory developed is of fundamental importance for any methods relying on a purely Lagrangian step, as ALE methods or non-direct Euler schemes.
lag_pos_2D.pdf (2.96 Mo) Télécharger le fichier
hal-01248913 , version 1 (29-12-2015)
François Vilar, Chi-Wang Shu, P.H. Maire. Positivity-preserving cell-centered Lagrangian schemes for multi-material compressible flows: From first-order to high-orders. Part II: The two-dimensional case. Journal of Computational Physics, 2016, 312, pp.416 - 442. ⟨10.1016/j.jcp.2016.01.037⟩. ⟨hal-01248913⟩
Collections
CEA DAM TDS-MACS
48 Consultations
94 Téléchargements
