Gain-scheduled output-feedback controllers depending solely on scheduling parameters via parameter-dependent Lyapunov functions, Automatica, vol.47, issue.12, pp.2786-2790, 2011. ,
DOI : 10.1016/j.automatica.2011.09.023
Observing the State of a Linear System, IEEE Transactions on Military Electronics, vol.8, issue.2, pp.74-80, 1964. ,
DOI : 10.1109/TME.1964.4323124
New Results in Linear Filtering and Prediction Theory, Journal of Basic Engineering, vol.83, issue.1, pp.95-108, 1961. ,
DOI : 10.1115/1.3658902
´ Etude préliminaire d'une commande sans modèle pour papillon de moteur ..... A modelfree control for an engine throttle: a preliminary study, Journal Européen des Systèmes Automatisés, vol.42, issue.2- 3, pp.337-354, 2008. ,
Parameter estimation for signals described by differential equations, Applicable Analysis, vol.26, issue.1, pp.29-52, 2009. ,
DOI : 10.1109/MED.2008.4602161
Sliding controller design for non-linear systems, International Journal of Control, vol.38, issue.2, pp.421-434, 1984. ,
DOI : 10.1080/00207178408933284
Robust adaptive sliding-mode control for continuous time-delay systems, IMA Journal of Mathematical Control and Information, vol.24, issue.3, pp.299-313, 2007. ,
DOI : 10.1093/imamci/dnl022
Robust sliding mode observer with parameters estimation for a class of nonlinear time-delay systems, 49th IEEE Conference on Decision and Control (CDC), pp.96-101 ,
DOI : 10.1109/CDC.2010.5717677
Terminal sliding mode observer based parameter estimation method for permanent magnet synchronous motor control system, 2010 11th International Workshop on Variable Structure Systems (VSS), pp.184-189, 2010. ,
DOI : 10.1109/VSS.2010.5544736
Linear matrix inequalities in system and control theory, SIAM, vol.15, pp.23-24, 1994. ,
DOI : 10.1137/1.9781611970777
