A survey of scheduling problems with setup times or costs, European Journal of Operational Research, vol.187, issue.3, pp.985-1032, 2008. ,
DOI : 10.1016/j.ejor.2006.06.060
Santa claus meets hypergraph matchings, ACM Transactions on Algorithms, vol.8, issue.3, pp.1-249, 2012. ,
DOI : 10.1145/2229163.2229168
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.140.3137
The Santa Claus problem, Proceedings of the thirty-eighth annual ACM symposium on Theory of computing , STOC '06, pp.31-40, 2006. ,
DOI : 10.1145/1132516.1132522
Lot-sizing scheduling with batch setup times, Journal of Scheduling, vol.103, issue.1???3, pp.299-310, 2006. ,
DOI : 10.1007/s10951-006-8265-7
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.5.6888
Approximation algorithms for scheduling splitting jobs with setup times (2013) Talk in MAPSP ,
Graph Balancing: A Special Case of Scheduling Unrelated Parallel Machines, Algorithmica, vol.143, issue.1, 1007. ,
DOI : 10.1007/s00453-012-9668-9
A threshold of ln n for approximating set cover, Journal of the ACM, vol.45, issue.4, pp.634-652, 1998. ,
DOI : 10.1145/285055.285059
On allocations that maximize fairness, pp.287-293, 2008. ,
Optimization and Approximation in Deterministic Sequencing and Scheduling: a Survey, Ann. Discrete Math, vol.5, pp.287-326, 1979. ,
DOI : 10.1016/S0167-5060(08)70356-X
Geometric Algorithms and Combinatorial Optimization, 1988. ,
New Constructive Aspects of the Lov??sz Local Lemma, Journal of the ACM, vol.58, issue.6, pp.1-28, 2011. ,
DOI : 10.1145/2049697.2049702
Fast Approximation Algorithms for the Knapsack and Sum of Subset Problems, Journal of the ACM, vol.22, issue.4, pp.463-468, 1975. ,
DOI : 10.1145/321906.321909
Unrelated parallel machine scheduling with setup times and a total weighted tardiness objective, Robotics and Computer-Integrated Manufacturing, vol.19, issue.1-2, pp.173-181, 2003. ,
DOI : 10.1016/S0736-5845(02)00077-7
Approximation algorithms for scheduling unrelated parallel machines, Mathematical Programming, vol.23, issue.1-3, pp.259-271, 1990. ,
DOI : 10.1007/BF01585745
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.115.708
Minimizing Total Completion Time Subject to Job Release Dates and Preemption Penalties, Journal of Scheduling, vol.7, issue.4, pp.313-327, 2004. ,
DOI : 10.1023/B:JOSH.0000031424.35504.c4
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.509.3602
Cones of Matrices and Set-Functions and 0???1 Optimization, SIAM Journal on Optimization, vol.1, issue.2, pp.166-190, 1991. ,
DOI : 10.1137/0801013
Quasi-polynomial Local Search for Restricted Max-Min Fair Allocation, pp.726-737, 2012. ,
DOI : 10.1007/978-3-642-31594-7_61
URL : http://arxiv.org/abs/1205.1373
Integrating Scheduling with Batching and Lot-Sizing: A Review of Algorithms and Complexity, Journal of the Operational Research Society, vol.43, issue.5, pp.395-406, 1992. ,
DOI : 10.1057/jors.1992.66
Split scheduling with uniform setup times, Journal of Scheduling, vol.103, issue.1???3, pp.1-11, 2014. ,
DOI : 10.1007/s10951-014-0370-4
URL : https://hal.archives-ouvertes.fr/hal-01249095
Theory of Linear and Integer Programming, 1986. ,
Preemptive scheduling with job-dependent setup times, pp.759-767, 1999. ,
Scheduling Jobs on Several Machines with the Job Splitting Property, Operations Research, vol.44, issue.4, pp.617-628, 1996. ,
DOI : 10.1287/opre.44.4.617
Semi-infinite programming, duality, discretization and optimality conditions???, Optimization, vol.91, issue.2, pp.133-161, 2009. ,
DOI : 10.1214/aoms/1177700153
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.154.2108
Santa Claus Schedules Jobs on Unrelated Machines, SIAM Journal on Computing, vol.41, issue.5, pp.1318-1341, 2012. ,
DOI : 10.1137/110851201
URL : http://arxiv.org/abs/1011.1168
Approximating the Configuration-LP for Minimizing Weighted Sum of Completion Times on Unrelated Machines, pp.387-398, 2013. ,
DOI : 10.1007/978-3-642-36694-9_33
The allocation of scarce resources in disaster relief, 2010. ,
On the configuration-LP for scheduling on unrelated machines, pp.530-542, 2011. ,
The Design of Approximation Algorithms, 2011. ,
DOI : 10.1017/CBO9780511921735
Parallel machine scheduling with splitting jobs, Discrete Applied Mathematics, vol.103, issue.1-3, pp.259-269, 2000. ,
DOI : 10.1016/S0166-218X(00)00176-1
URL : http://doi.org/10.1016/s0166-218x(00)00176-1
