Competition: Channel Exploration/Exploitation Based on a Thompson Sampling Approach in a Radio Cognitive Environment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Machine learning approaches have been extensively applied in interference mitigation and cognitive radio devices. In this work, we model the spectrum selection process as a multi-arm bandit problem and apply Thompson sampling, a fast and efficient algorithm, to find the best channel in the shortest time interval. The learning algorithm will work on top of a network layer to efficiently route the event information to the sink.
Final.pdf (120.7 Ko) Télécharger le fichier
hal-01249135 , version 1 (30-12-2015)
  • HAL Id : hal-01249135 , version 1
Arash Maskooki, Viktor Toldov, Laurent Clavier, Valeria Loscrì, Nathalie Mitton. Competition: Channel Exploration/Exploitation Based on a Thompson Sampling Approach in a Radio Cognitive Environment. EWSN - International Conference on Embedded Wireless Systems and Networks (dependability competition), Feb 2016, Graz, Austria. ⟨hal-01249135⟩
328 Consultations
174 Téléchargements
