Generalized Nevanlinna-Pick interpolation on the boundary. Application to impedance matching - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
This work deal with interpolation of complex values by a Schur rational functions of prescribed degree at a set of nodes located in the closed disk, with prescribed maximum points for the modulus (i.e. where it is equal to 1) on the circle. The motivation comes from broadband matching, for which the technique we develop offers a new tool.
Articletronque.pdf (298.57 Ko) Télécharger le fichier
hal-01249330 , version 1 (31-12-2015)
  • HAL Id : hal-01249330 , version 1
Laurent Baratchart, Martine Olivi, Fabien Seyfert. Generalized Nevanlinna-Pick interpolation on the boundary. Application to impedance matching. 2015. ⟨hal-01249330⟩
Collections
INRIA INRIA2
393 Consultations
124 Téléchargements
