Conference papers
Tight Bounds on Vertex Connectivity Under Vertex Sampling
Abstract : A fundamental result by Karger (SODA 1994) states that for any λ-edge-connected graph with n nodes, independently sampling each edge with probability p = Ω(log n/λ) results in a graph that has edge connectivity Ω(λp), with high probability. This paper proves the analogous result for vertex connectivity, when sampling vertices. We show that for any k-vertex-connected graph G with n nodes, if each node is independently sampled with probability p = Ω(log n/k), then the subgraph induced by the sampled nodes has vertex connectivity Ω(kp^2), with high probability. This bound improves upon the recent results of Censor-Hillel et al. (SODA 2014), and is existentially optimal.
Document type :
Conference papers
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/hal-01250519
Contributor : George Giakkoupis Connect in order to contact the contributor
Submitted on : Monday, January 4, 2016 - 11:06:17 PM
Last modification on : Friday, January 21, 2022 - 3:10:18 AM
File
soda15_kvc.pdf
Identifiers
Citation
Keren Censor-Hillel, Mohsen Ghaffari, George Giakkoupis, Bernhard Haeupler, Fabian Kuhn. Tight Bounds on Vertex Connectivity Under Vertex Sampling. 26th Annual ACM-SIAM Symposium on Discrete Algorithms (SODA 2015), Jan 2015, San Diego, CA, United States. pp.2006-1018, ⟨10.1137/1.9781611973730.133⟩. ⟨hal-01250519⟩
Share
Metrics
Record views
203
Files downloads
99
