Wait-free test-and-set, Proceedings of the 6th International Workshop on Distributed Algorithms (WDAG), pp.85-94, 1992. ,
Space- and Time-Efficient Long-Lived Test-And-Set Objects, Proceedings of the 18th International Conference on Principles of Distributed Computing (OPODIS), pp.404-419, 2014. ,
DOI : 10.1007/978-3-319-14472-6_27
Sub-logarithmic Test-and-Set against a Weak Adversary, Proceedings of the 25th International Symposium on Distributed Computing (DISC), pp.97-109, 2011. ,
DOI : 10.1007/s004460200071
Optimal-time adaptive strong renaming, with applications to counting, Proceedings of the 30th annual ACM SIGACT-SIGOPS symposium on Principles of distributed computing, PODC '11, pp.239-248, 2011. ,
DOI : 10.1145/1993806.1993850
The Complexity of Renaming, 2011 IEEE 52nd Annual Symposium on Foundations of Computer Science, pp.718-727, 2011. ,
DOI : 10.1109/FOCS.2011.66
Fast Randomized Test-and-Set and Renaming, Proceedings of the 24th International Symposium on Distributed Computing (DISC), pp.94-108, 2010. ,
DOI : 10.1007/978-3-642-15763-9_9
On the importance of having an identity or, is consensus really universal? Distributed Computing, pp.167-176, 2006. ,
Bounds on Shared Memory for Mutual Exclusion, Information and Computation, vol.107, issue.2, pp.171-184, 1993. ,
DOI : 10.1006/inco.1993.1065
Long-lived, fast, waitfree renaming with optimal name space and high throughput, Proceedings of the 12th International Symposium on Distributed Computing (DISC), pp.149-160, 1998. ,
DOI : 10.1007/BFb0056480
Obstruction-Free Algorithms Can Be Practically Wait-Free, Proceedings of the 19th International Symposium on Distributed Computing (DISC), pp.78-92, 2005. ,
DOI : 10.1007/11561927_8
An $O(\sqrt n)$ Space Bound for Obstruction-Free Leader Election, Proceedings of the 27th International Symposium on Distributed Computing (DISC), pp.46-60, 2013. ,
DOI : 10.1007/978-3-642-41527-2_4
URL : https://hal.archives-ouvertes.fr/hal-00875167
On the time and space complexity of randomized test-and-set, Proceedings of the 2012 ACM symposium on Principles of distributed computing, PODC '12, pp.19-28 ,
DOI : 10.1145/2332432.2332436
URL : https://hal.archives-ouvertes.fr/hal-00722947
A tight RMR lower bound for randomized mutual exclusion, Proceedings of the 44th symposium on Theory of Computing, STOC '12, pp.983-1002, 2012. ,
DOI : 10.1145/2213977.2214066
URL : https://hal.archives-ouvertes.fr/hal-00722940
An $O(1)$ RMRs Leader Election Algorithm, SIAM Journal on Computing, vol.39, issue.7, pp.2726-2760, 2010. ,
DOI : 10.1137/070686445
Toward a theory of transactional contention managers, Proceedings of the 24th SIGACT-SIGOPS Symposium on Principles of Distributed Computing (PODC), pp.258-264, 2005. ,
Wait-free synchronization, ACM Transactions on Programming Languages and Systems, vol.13, issue.1, pp.124-149, 1991. ,
DOI : 10.1145/114005.102808
Obstruction-free synchronization: Double-ended queues as an example Time and space lower bounds for nonblocking implementations, Proceedings of the 23rd International Conference on Distributed Computing Systems (ICDCS), pp.522-529438, 2000. ,
Efficient synchronization of multiprocessors with shared memory, ACM Transactions on Programming Languages and Systems, vol.10, issue.4, pp.579-601, 1988. ,
DOI : 10.1145/48022.48024
Randomized naming using wait-free shared variables, Distributed Computing, pp.113-124, 1998. ,
DOI : 10.1007/s004460050045
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.12.6861
Tight bounds for shared memory symmetric mutual exclusion problems, Proceedings of the eighth annual ACM Symposium on Principles of distributed computing , PODC '89, pp.177-191, 1989. ,
DOI : 10.1145/72981.72993
Randomized two-process wait-free test-and-set, Distributed Computing, vol.15, issue.3, pp.127-135, 2002. ,
