Asymptotic behavior of acoustic waves scattered by very small obstacles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2021
The direct numerical simulation of the acoustic wave scattering created by very small obstacles is very expensive, especially in three dimensions and even more so in time domain. The use of asymptotic models is very efficient and the purpose of this work is to provide a rigorous justification of a new asymptotic model for low-cost numerical simulations. This model is based on asymptotic near-field and far-field developments that are then matched by a key procedure that we describe and demonstrate. We show that it is enough to focus on the regular part of the wave field to rigorously establish the complete asymptotic expansion. For that purpose, we provide an error estimate which is set in the whole space, includingthe transition region separating the near-field from the far-field area. The proof of convergence is established through Kondratiev’s seminal work on the Laplace equation and involves the Mellin transform. Numerical experiments including multiple scattering illustrate the efficiency of the resulting numerical method by delivering some comparisons with solutions computed with a finite element software.
M2AN_BDMT_2020.pdf (2.69 Mo) Télécharger le fichier
hal-01250654 , version 1 (05-01-2016)
hal-01250654 , version 2 (07-07-2020)
Hélène Barucq, Julien Diaz, Vanessa Mattesi, Sébastien Tordeux. Asymptotic behavior of acoustic waves scattered by very small obstacles. ESAIM: Mathematical Modelling and Numerical Analysis, 2021, 55, pp.705 - 731. ⟨10.1051/m2an/2020047⟩. ⟨hal-01250654v2⟩
293 Consultations
192 Téléchargements
