Being prepared in a sparse world: the case of KNN graph construction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
K-Nearest-Neighbor (KNN) graphs have emerged as a fundamental building block of many on-line services providing recommendation, similarity search and classification. Constructing a KNN graph rapidly and accurately is, however, a computationally intensive task. As data volumes keep growing, speed and the ability to scale out are becoming critical factors when deploying a KNN algorithm. In this work, we present KIFF, a generic, fast and scalable KNN graph construction algorithm. KIFF directly exploits the bipartite nature of most datasets to which KNN algorithms are applied. This simple but powerful strategy drastically limits the computational cost required to rapidly converge to an accurate KNN solution, especially for sparse datasets. Our evaluation on a representative range of datasets show that KIFF provides, on average, a speed-up factor of 14 against recent state-of-the art solutions while improving the quality of the KNN approximation by 18%.
PID4067857.pdf (975.78 Ko) Télécharger le fichier
hal-01251010 , version 1 (30-06-2016)
  • HAL Id : hal-01251010 , version 1
Antoine Boutet, Anne-Marie Kermarrec, Nupur Mittal, François Taïani. Being prepared in a sparse world: the case of KNN graph construction. International Conference on Data Engineering (ICDE), May 2016, Helsinki, Finland. ⟨hal-01251010⟩
Relations
764 Consultations
1029 Téléchargements
