The ParaView Guide: A Parallel Visualization Application, 2015. ,
ON UNIQUENESS FOR TIME HARMONIC ANISOTROPIC MAXWELL'S EQUATIONS WITH PIECEWISE REGULAR COEFFICIENTS, Mathematical Models and Methods in Applied Sciences, vol.22, issue.11, 2012. ,
DOI : 10.1142/S0218202512500364
Regularized Combined Field Integral Equations, Numerische Mathematik, vol.74, issue.1, pp.1-19, 2005. ,
DOI : 10.1007/s00211-004-0579-9
The Application of Integral Equation Methods to the Numerical Solution of Some Exterior Boundary-Value Problems, Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.323, issue.1553, pp.201-210, 1553. ,
DOI : 10.1098/rspa.1971.0097
A surface formulation for characteristic modes of material bodies, IEEE Transactions on Antennas and Propagation, vol.25, issue.6, pp.789-795, 1977. ,
DOI : 10.1109/TAP.1977.1141685
A single trace integral formulation of the second kind for acoustic scattering, Seminar for Applied Mathematics, ETH Zürich, 2011. ,
Multi-Trace Boundary Integral Formulation for Acoustic Scattering by Composite Structures, Communications on Pure and Applied Mathematics, vol.11, issue.no. 2, p.11631201, 2013. ,
DOI : 10.1002/cpa.21462
Integral Equations for Acoustic Scattering by Partially Impenetrable Composite Objects. Integral Equations Operator Theory, pp.151-189, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01094440
Multitrace boundary integral equations, Direct and Inverse Problems in Wave Propagation and Applications, Radon Series on Computational and Applied Mathematics, pp.51-100, 2013. ,
DOI : 10.1515/9783110282283.51
Novel Multi- Trace Boundary Integral Equations for Transmission Boundary Value Problems, Unified Transform for Boundary Value Problems: Applications and Advances, SIAM, 2015. ,
A second-kind Galerkin boundary element method for scattering at composite objects, BIT Numerical Mathematics, vol.8, issue.2, pp.33-57, 2015. ,
DOI : 10.1007/s10543-014-0496-y
URL : https://hal.archives-ouvertes.fr/hal-00909835
Inverse Acoustic and Electromagnetic Scattering Theory, 2012. ,
A direct boundary integral equation method for transmission problems, Journal of Mathematical Analysis and Applications, vol.106, issue.2, pp.367-413, 1985. ,
DOI : 10.1016/0022-247X(85)90118-0
Boundary integral equations for mixed boundary value problems in polygonal domains and Galerkin approximation, pp.175-251, 1985. ,
The double layer potential operator over polyhedral domains i: solvability in weighted sobolev spaces, Applicable Analysis, vol.24, issue.1-4, pp.117-134, 1992. ,
DOI : 10.1016/0022-1236(84)90066-1
Gmsh: A 3-D finite element mesh generator with built-in pre- and post-processing facilities, International Journal for Numerical Methods in Engineering, vol.69, issue.4, pp.791309-1331, 2009. ,
DOI : 10.1002/nme.2579
Stable and accurate integral equation methods for scattering problems with multiple material interfaces in two dimensions, Journal of Computational Physics, vol.231, issue.6, pp.2389-2395, 2012. ,
DOI : 10.1016/j.jcp.2011.11.034
Singularities in boundary value problems, Recherches en mathématiques appliquées, 1992. ,
Boundary Integral Formulations for Homogeneous Material Bodies, Journal of Electromagnetic Waves and Applications, vol.32, issue.1, pp.1-15, 1989. ,
DOI : 10.1163/156939389X00016
On the Solution of Time-Harmonic Scattering Problems for Maxwell???s Equations, SIAM Journal on Mathematical Analysis, vol.27, issue.6, pp.1597-1630, 1996. ,
DOI : 10.1137/S0036141094271259
Operator Preconditioning, Computers & Mathematics with Applications, vol.52, issue.5, pp.699-706, 2006. ,
DOI : 10.1016/j.camwa.2006.10.008
Multiple traces boundary integral formulation for Helmholtz transmission problems, Advances in Computational Mathematics, vol.11, issue.4, pp.39-91, 2012. ,
DOI : 10.1007/s10444-011-9194-3
BETL -a generic boundary element template library, Seminar for Applied Mathematics, ETH Zürich, 2012. ,
The Inhomogeneous Dirichlet Problem in Lipschitz Domains, Journal of Functional Analysis, vol.130, issue.1, pp.161-219, 1995. ,
DOI : 10.1006/jfan.1995.1067
Transmission problems for the Helmholtz equation, Journal of Mathematical Physics, vol.19, issue.6, pp.1433-1437, 1978. ,
DOI : 10.1063/1.523808
Strongly Elliptic Systems and Boundary Integral Equations, 2000. ,
Zur Formulierung eines allgemeinen Beugungsproblems durch eine Integralgleichung, Zeitschrift für Physik, pp.601-618, 1949. ,
Foundations of the mathematical theory of electromagnetic waves, 1969. ,
DOI : 10.1007/978-3-662-11773-6
Computations of Electromagnetic Wave Scattering From Penetrable Composite Targets Using a Surface Integral Equation Method With Multiple Traces, IEEE Transactions on Antennas and Propagation, vol.61, issue.1, pp.256-270, 2013. ,
DOI : 10.1109/TAP.2012.2220098
Integral Equation Based Domain Decomposition Method for Solving Electromagnetic Wave Scattering From Non-Penetrable Objects, IEEE Transactions on Antennas and Propagation, vol.59, issue.9, p.33283338, 2011. ,
DOI : 10.1109/TAP.2011.2161542
Integral Equation Solutions of Three-dimensional Scattering Problems, Computer Techniques for Electromagnetics, chapter, pp.159-263, 1973. ,
DOI : 10.1016/B978-0-08-016888-3.50008-8
Solution of acoustic scattering problems by means of second kind integral equations, Wave Motion, vol.5, issue.3, pp.257-272, 1983. ,
DOI : 10.1016/0165-2125(83)90016-1
Boundary element methods, 2011. ,
Numerical approximation methods for elliptic boundary value problems: finite and boundary elements, 2008. ,
DOI : 10.1007/978-0-387-68805-3
Boundary integral equations for mixed Dirichlet, Neumann and transmission problems, Mathematical methods in the applied sciences, pp.185-213, 1989. ,
DOI : 10.1002/mma.1670110203
Scattering from arbitrarily-shaped lossy dielectric bodies of revolution, A. Paganini and S. Sargheini and R. Hiptmair and C. Hafner Shape Optimization of microlenses 2015-16 V. Kazeev and Ch. Schwab Approximation of Singularities by Quantized-Tensor FEM, pp.709-718, 1977. ,
DOI : 10.1029/RS012i005p00709
