Development of a safe CPS component: the hybrid parachute, a remote termination add-on improving safety of UAS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The use of Unmanned Aerial Systems (UAS) can be leveraged in many application domains ranging from agriculture to industry, opening up a wealth of new possibilities. However, UAS obviously raise important safety concerns and the use of the techniques, processes and standards developed for the aeronautic industry is not a feasible solution for most UAS. There is a need to bring in novel and pragmatic solutions to develop provably safe UAS in a time and cost-affordable manner. This paper reports on the development of a smart parachute which provides a safe-crash (termination) solution for UAS, one of the core safety requirements which can be complemented by other safety components in an incremental manner. The requirements elicitation phase, the design and partial verification of the termination system has been carried out using CPAL, a lightweight model-based design environment for embedded systems. The study illustrates on a specific requirement of the system how simulation and fault-injection on models can be used to provide evidence that the parachute system meets its design objectives.
paper_108.pdf (1.62 Mo) Télécharger le fichier
hal-01251305 , version 1 (05-01-2016)
  • HAL Id : hal-01251305 , version 1
Laurent Ciarletta, Loïc Fejoz, Adrien Guenard, Nicolas Navet. Development of a safe CPS component: the hybrid parachute, a remote termination add-on improving safety of UAS. ERTS 2016 - 8th European Congress on Embedded Real Time Software and Systems, Jan 2016, Toulous, France. pp.10. ⟨hal-01251305⟩
269 Consultations
222 Téléchargements
