A mesh-dependent model for applying dynamic contact angles to VOF simulations, Journal of Computational Physics, vol.228, issue.15, p.53705389, 2009. ,
DOI : 10.1016/j.jcp.2009.04.027
A penalization method to take into account obstacles in incompressible viscous ows, Numerische Mathematik, vol.81, issue.4, p.497520, 1999. ,
Dynamic of polymeric liquids, 1987. ,
The physics of moving wetting lines, Journal of Colloid and Interface Science, vol.299, issue.1, p.113, 2006. ,
DOI : 10.1016/j.jcis.2006.03.051
Wetting and spreading, Reviews of Modern Physics, vol.81, issue.2, p.739805, 2009. ,
DOI : 10.1103/RevModPhys.81.739
Boundary conditions on articial frontiers for incompressible and compressible navier-stokes equations, Mathematical Modelling and Numerical Analysis, vol.34, issue.2, p.12, 2000. ,
Modeling moving droplets: A precursor lm approach, 2003. ,
A level set formulation of eulerian interface capturing methods for incompressible uid ows, Journal of Computational Physics, vol.124, issue.2, p.449464, 1996. ,
Interface and contact line motion in a two phase uid under shear ow, Physical Review Letters, vol.85, issue.8, p.16861689, 2000. ,
Computing minimal surfaces via level set curvature ow, Journal of Computational Physics, vol.106, issue.1, p.7791, 1993. ,
Drainage in two-dimensional porous media: From capillary fingering to viscous flow, Physical Review E, vol.82, issue.4, p.46315, 2010. ,
DOI : 10.1103/PhysRevE.82.046315
The dynamics of the spreading of liquids on a solid surface. part 1. viscous ow, Journal of Fluid Mechanics, vol.168, p.169194, 1986. ,
Wetting statics and dynamics, Reviews of Modern Physics, vol.57, issue.3, p.827863, 1985. ,
Global models for moving contact lines. Physical review. E, Statistical, nonlinear, and soft matter physics ,
Wetting condition in diffuse interface simulations of contact line motion, Physical Review E, vol.75, issue.4, p.46708, 2007. ,
DOI : 10.1103/PhysRevE.75.046708
Numerical simulation of static and sliding drop with contact angle hysteresis, Journal of Computational Physics, vol.229, issue.7, pp.2453-2478, 2010. ,
DOI : 10.1016/j.jcp.2009.07.034
On the Spreading of Liquids on Solid Surfaces: Static and Dynamic Contact Lines, Annual Review of Fluid Mechanics, vol.11, issue.1, p.371400, 1979. ,
DOI : 10.1146/annurev.fl.11.010179.002103
Augmented Lagrangian methods: Applications to the Numerical Solution of Boundary-Value Problems, 1983. ,
On stability condition for biuid ows with surface tension: Application to microuidics, Journal of Computational Physics, vol.227, issue.12, p.61406164, 2008. ,
Development and application of a parallel multigrid solver for the simulation of spreading droplets, International Journal for Numerical Methods in Fluids, vol.13, issue.8, p.56979989, 2008. ,
DOI : 10.1002/fld.1737
Generalized Navier boundary condition and geometric conservation law for surface tension, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.5-8, pp.5-8644656, 2009. ,
DOI : 10.1016/j.cma.2008.09.011
URL : https://hal.archives-ouvertes.fr/inria-00542241
A moving uid interface. part 2. the removal of the force singularity by a slip ow, Journal of Fluid Mechanics, issue.02, p.79209229, 1977. ,
A study of the advancing interface. i. interface shape in liquidgas systems, Journal of Colloid and Interface Science, vol.50, issue.2, p.228241, 1975. ,
Contact-line dynamics of a diuse uid interface, Journal of Fluid Mechanics, vol.402, p.5788, 2000. ,
Ecient implementation of weighted eno schemes, J. Comput. Phys, vol.126, issue.1, p.202228, 1996. ,
Capillary spreading of a droplet in the partially wetting regime using a diuse-interface model, Journal of Fluid Mechanics, vol.572, p.367387, 2007. ,
Constitutive Equations for Polymer Melts and Solutions, Butterworths, 1988. ,
Microuidics: The No-Slip Boundary Condition in Handbook on Experimental Fluid Dynamics, 2007. ,
Partial dierentia Equations of Thin Liquid Films: Analysis and Numerical Simulation, 2005. ,
Weighted Essentially Non-oscillatory Schemes, Journal of Computational Physics, vol.115, issue.1, p.200212, 1994. ,
DOI : 10.1006/jcph.1994.1187
Unsteady spreading of thin liquid lms with small surface tension. Physics of Fluids A: Fluid Dynamics, p.733742, 1991. ,
Level Set Methods and Dynamic Implicit Surfaces, 2002. ,
Molecular hydrodynamics of the moving contact line in two-phase immiscible ows, Communications in Computational Physics, vol.1, issue.1, p.152, 2005. ,
Generalized Navier Boundary Condition for the Moving Contact Line, Communications in Mathematical Sciences, vol.1, issue.2, p.333341, 2003. ,
DOI : 10.4310/CMS.2003.v1.n2.a7
Moving contact line problem: state of the contact angle boundary condition, Encyclopedia of Surface and Colloid Science, p.36023618, 2002. ,
Boundary conditions for the moving contact line problem, Physics of Fluids, vol.19, issue.2, p.22101, 2007. ,
DOI : 10.1063/1.2646754
Reconstructing Volume Tracking, Journal of Computational Physics, vol.141, issue.2, p.112152, 1998. ,
DOI : 10.1006/jcph.1998.5906
Méthodes de domaines ctifs d'ordre élevé pour les équations elliptiques et de Navier Stokes Application au couplage uide structure, 2009. ,
Direct numerical simulation of free-surface and interfacial ow, Annual Review of Fluid Mechanics, vol.31, issue.1, p.567603, 1999. ,
Simulation of droplet motion on lowenergy and heterogeneous surfaces, Journal of Colloid and Interface Science, vol.202, issue.1, p.173188, 1998. ,
Moving contact lines in the Cahn-Hilliard theory, International Journal of Engineering Science, vol.34, issue.9, p.977992, 1996. ,
DOI : 10.1016/0020-7225(95)00141-7
URL : https://hal.archives-ouvertes.fr/hal-00527283
A fast marching level set method for monotonically advancing fronts., Proceedings of the National Academy of Sciences, vol.93, issue.4, p.15911595, 1996. ,
DOI : 10.1073/pnas.93.4.1591
Level set methods and fast marching methods, 1999. ,
Immiscible-uid displacement: Contact-line dynamics and the velocity-dependent capillary pressure, Physical Review A, issue.8, p.455694, 1992. ,
Capillary Flows with Forming Interfaces, 2007. ,
DOI : 10.1201/9781584887492
A level-set approach for simulations of ows with multiple moving contact lines with hysteresis, Journal of Computational Physics, vol.207, issue.2, p.389404, 2005. ,
Effect of artificial stress diffusivity on the stability of numerical calculations and the flow dynamics of time-dependent viscoelastic flows, Journal of Non-Newtonian Fluid Mechanics, vol.60, issue.1, pp.53-80, 1995. ,
DOI : 10.1016/0377-0257(95)01377-8
A method for overcoming the surface tension time step constraint in multiphase ows ii, International Journal for Numerical Methods in Fluids, vol.68, issue.11, p.13431361, 2012. ,
Calcul numérique et stabilité d écoulements diphasiques tridimiensionnels en microuidique, 2007. ,
Simulations of contact-line motion: Slip and the dynamic contact angle, Physical Review Letters, vol.63, issue.7, p.766769, 1989. ,
DOI : 10.1103/PhysRevLett.63.766
A front tracking method for viscous , incompressible, multi-uid ows, Journal of Computational Physics, vol.100, issue.1, p.2537, 1992. ,
Méthodes Level Set pour des problèmes d'interface en microuidique, 2007. ,
Contact line treatment with the sharp interface method, Computers & Fluids, vol.84, issue.0, pp.255-261, 2013. ,
DOI : 10.1016/j.compfluid.2013.04.006
Linear instability of the fth-order weno method, SIAM Journal on Numerical Analysis, vol.45, issue.5, p.18711901, 2007. ,
Analyse par simulation numérique de la réduction de la traînée et des caractéristiques d'écoulements bidimensionnels par l'ajout de polymères en solution, 2010. ,
Phase-eld simulations of dynamic wetting of viscoelastic uids, Journal of Non-Newtonian Fluid Mechanics, issue.0, pp.1891908-1891921, 2012. ,
A conservative level set method for contact line dynamics, Journal of Computational Physics, vol.228, issue.17, p.63616375, 2009. ,
DOI : 10.1016/j.jcp.2009.05.043
