Linear space bootstrap communication schemes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theoretical Computer Science Année : 2015
Carole Delporte-Gallet
  • Fonction : Auteur
  • PersonId : 927652
Hugues Fauconnier
  • Fonction : Auteur
  • PersonId : 858850
Eli Gafni
  • Fonction : Auteur
  • PersonId : 830509
Sergio Rajsbaum
  • Fonction : Auteur
  • PersonId : 830510
Consider a system of n processes with ids that are drawn from a large space. How can these n processes communicate to solve a problem? It is shown that linear number of Multi-Writer Multi-Reader (MWMR) registers are sufficient to solve any read-write wait-free solvable problem and needed to solve some read-write wait-free solvable problem. This contrasts with the existing possible solution borrowed from adaptive algorithms that require Θ(n3/2) MWMR registers. To obtain the sufficiency result, the paper shows how the processes can non-blocking emulate a system of n Single-Writer Multi-Reader (SWMR) registers on top of n Multi-Writer Multi-Reader (MWMR) registers. For the necessity result, it shows it is impossible to do such an emulation with n−1 MWMR registers. The paper also presents a wait-free emulation, using 2n−1 rather than just n registers. The emulation can be used to solve an infinite sequence of tasks that are sequentially dependent (processes need the previous task's outputs in order to proceed to the next task). A non-blocking emulation cannot be used in this case, because it might starve a process forever
Informatique
hal-01251557 , version 1 (06-01-2016)
Carole Delporte-Gallet, Hugues Fauconnier, Eli Gafni, Sergio Rajsbaum. Linear space bootstrap communication schemes. Theoretical Computer Science, 2015, 561, pp.122-133. ⟨10.1016/j.tcs.2014.10.013⟩. ⟨hal-01251557⟩
109 Consultations
0 Téléchargements
