3D multimodal MRI brain glioma tumor and edema segmentation: a graph cut distribution matching approach. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computerized Medical Imaging and Graphics Année : 2015
This study investigates a fast distribution-matching, data-driven algorithm for 3D multimodal MRI brain glioma tumor and edema segmentation in different modalities. We learn non-parametric model distributions which characterize the normal regions in the current data. Then, we state our segmentation problems as the optimization of several cost functions of the same form, each containing two terms: (i) a distribution matching prior, which evaluates a global similarity between distributions, and (ii) a smoothness prior to avoid the occurrence of small, isolated regions in the solution. Obtained following recent bound-relaxation results, the optima of the cost functions yield the complement of the tumor region or edema region in nearly real-time. Based on global rather than pixel wise information, the proposed algorithm does not require an external learning from a large, manually-segmented training set, as is the case of the existing methods. Therefore, the ensuing results are independent of the choice of a training set. Quantitative evaluations over the publicly available training and testing data set from the MICCAI multimodal brain tumor segmentation challenge (BraTS 2012) demonstrated that our algorithm yields a highly competitive performance for complete edema and tumor segmentation, among nine existing competing methods, with an interesting computing execution time (less than 0.5s per image).
Fichier non déposé
hal-01251570 , version 1 (06-01-2016)
Ines Njeh, Lamia Sallemi, Ismail Ben Ayed, Khalil Chtourou, Stéphane Lehéricy, et al.. 3D multimodal MRI brain glioma tumor and edema segmentation: a graph cut distribution matching approach.. Computerized Medical Imaging and Graphics, 2015, 40 (4), pp.108-19. ⟨10.1016/j.compmedimag.2014.10.009⟩. ⟨hal-01251570⟩
126 Consultations
0 Téléchargements
