Abstract : The study of problem difficulty is an open issue in Genetic Programming (GP). The
goal of this work is to generate models that predict the expected performance of a GPbased
classifier when it is applied to an unseen task. Classification problems are
described using domain-specific features, some of which are proposed in this work,
and these features are given as input to the predictive models. These models are
referred to as predictors of expected performance (PEPs). We extend this approach by
using an ensemble of specialized predictors (SPEP), dividing classification problems
into specified groups and choosing the corresponding SPEP. The proposed predictors
are trained using 2D synthetic classification problems with balanced datasets. The
models are then used to predict the performance of the GP classifier on unseen realworld
datasets that are multidimensional and imbalanced. Moreover, as we know, this
work is the first to provide a performance prediction of the GP classifier on test data,
while previous works focused on predicting training performance. Accurate predictive
models are generated by posing a symbolic regression task and solving it with GP.
These results are achieved by using highly descriptive features and including a
dimensionality reduction stage that simplifies the learning and testing process. The
proposed approach could be extended to other classification algorithms and used as
the basis of an expert system for algorithm selection.
