Multi-Output Partial Nonlinear Observer Normal Form - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
— This paper deals with the problem to estimate some states of a multi-output nonlinear dynamical system which is partially observable. To address this problem, this paper provides a set of geometrical conditions that guarantee the existence of a change of coordinates which decomposes the studied nonlinear dynamical system into two dynamical subsystems, where the first one is of the well-known output injection form. This transformed form allows us to design a simple reduced-order (Luenberger-like) observer to estimate the observable state.
Automatique
Fichier non déposé
hal-01252365 , version 1 (07-01-2016)
  • HAL Id : hal-01252365 , version 1
Wided Saadi, Driss Boutat, Gang Zheng, Lassaad Sbita. Multi-Output Partial Nonlinear Observer Normal Form. 54th IEEE Conference on Decision and Control (CDC), Dec 2015, Osaka, Japan. ⟨hal-01252365⟩
147 Consultations
0 Téléchargements
