Visual Vibrations to Simulate Taps on Different Materials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2015
This paper presents a haptic visualization technique for conveying material type through visual feedback, expressed as visible decaying sinusoidal vibration resulting from tapping an object. The technique employs cartoon-inspired visual effects and modulates the scale of the vibration to comply with visual perception. The results of a user study show that participants could successfully perceive three types of material (rubber, wood, and aluminum) using our novel visual effect.
Fichier non déposé
hal-01252665 , version 1 (07-01-2016)
Taku Hachisu, Gabriel Cirio, Maud Marchal, Anatole Lécuyer, Hiroyuki Kajimoto. Visual Vibrations to Simulate Taps on Different Materials. Haptic Interaction - Perception, Devices and Applications, 277 of the series Lecture Notes in Electrical Engineering., Springer, pp.297-303, 2015, 978-4-431-55689-3. ⟨10.1007/978-4-431-55690-9_54⟩. ⟨hal-01252665⟩
267 Consultations
0 Téléchargements
