Column generation integer programming for allocating jobs with periodic demand variations - Archive ouverte HAL Access content directly
Conference Papers Year :
In the context of service hosting in large-scale datacenters, we consider the problem faced by a provider for allocating services to machines. An analysis of a public Google trace corresponding to the use of a production cluster over a long period shows that long-running services experience demand variations with a periodic (daily) pattern, and that services with such a pattern account for most of the overall CPU demand. This leads to an allocation problem where the classical Bin-Packing issue is augmented with the possibility to co-locate jobs whose peaks occur at different times of the day, which is bound to be more efficient than the usual approach that consist in over-provisioning for the maximum demand. In this paper, we propose a column-generation approach to solving this problem, where the subproblem uses a sophisticated SOCP (Second Order Cone Program) formulation. This allows to explicitely select jobs which benefit from being co-allocated together. Experimental results comparing with theoretical lower bounds and with standard packing heuristics shows that this approach is able to provide very efficient assignments in reasonable time.
ALGOCLOUD_2015_Ikbel BELAID.pdf (315.97 Ko) Télécharger le fichier
Dates and versions
hal-01252770 , version 1 (08-01-2016)
Identifiers
  • HAL Id : hal-01252770 , version 1
Cite
Ikbel Belaid, Lionel Eyraud-Dubois. Column generation integer programming for allocating jobs with periodic demand variations. International Workshop on Algorithmic Aspects of Cloud Computing, Sep 2015, Patras, Greece. ⟨hal-01252770⟩
209 View
260 Download
Share
