Safe Suggestions Based on Type Convertibility to Guide Workflow Composition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper proposes an interactive approach that guides users in the step-by-step composition of services by providing safe suggestions based on type convertibility. Users specify the points of the workflow (called the focus) they want to complete, and our approach suggests services and connections whose data types are compatible with the focus. We prove the safeness (every step produces a well-formed workflow) and the completeness (every well-formed workflow can be built) of our approach.
final.pdf (179.27 Ko) Télécharger le fichier
hal-01252775 , version 1 (08-01-2016)
Mouhamadou Ba, Sébastien Ferré, Mireille Ducassé. Safe Suggestions Based on Type Convertibility to Guide Workflow Composition. Foundations of Intelligent Systems (ISMIS), Oct 2015, Lyon, France. ⟨10.1007/978-3-319-25252-0_25⟩. ⟨hal-01252775⟩
263 Consultations
146 Téléchargements
